Lost log books
Old January 25th 07, 05:04 AM posted to rec.aviation.piloting
Aluckyguess
Default Lost log books
I looked at an A36 and was thinking about buying it, but he lost the logs.
My question is how much does this usually decrease the value of the plane.
Old January 25th 07, 06:15 AM posted to rec.aviation.piloting
BT
he's got zero logbooks for it?
start running.. away... very far away and as fast as you can..
BT
"Aluckyguess" wrote in message
Old January 25th 07, 06:53 AM posted to rec.aviation.piloting
Jim Macklin
Without logs, how do you know the flight hours on the
airframe or engine? Without that, how do you comply with AD
notes?
But if the plane looks good and he can prove ownership, you
can re-create the logs from sources.
The FAA should have records on the airplane. Beech will
have records of manufacture and probably spare parts orders.
It is some detective work and some parts, such as engines
and props may need to be overhauled or replaced anyway.
Talk to a good A&P/AI who "knows the model" and do a little
research.
My guess is that the price should be adjusted $25,000 to
$100,000 lower than a "perfect" airplane to cover your
costs.
You will need a real annual inspection by YOUR mechanic, not
his. That will cost several thousand dollars, just for the
inspection and logbook research just to find out what MUST
be replaced or re-done.
James H. Macklin
ATP,CFI,A&P
"BT" wrote in message
can..
| BT
he lost the logs.
value of the plane.
Old January 25th 07, 07:02 AM posted to rec.aviation.piloting
buttman
It's perfectly reasonable that a well maintained plane could have it's
logbooks go missing.
The flight school I work at has all the logbooks for their planes
stored in one room by the maintenance hangar. If that thing goes up in
flames, the planes are no less flyable.
Old January 25th 07, 12:57 PM posted to rec.aviation.piloting
Lou
I would hope someone was smart enough to buy a fire proof safe for that
room.
If they did go up in flames how would your student take their
checkride?
Lou
Old January 25th 07, 02:00 PM posted to rec.aviation.piloting
Peter Dohm
room.
Great idea, but that would put them on a different "plane of reality" from
most places I recall working. Admittedly, none were aircraft
operators--but...
Peter
Old January 25th 07, 04:12 PM posted to rec.aviation.piloting
Aluckyguess
"Jim Macklin" wrote in message
notes?
He can and he has one annual done on it. The A/P had the hours in his
computer.
He has that disk and the number of the guy who owned the plane before him.
He just did the prop it has 1 hour.
research.
I would do a complete annual using my mechanic as a pre buy.
That was my guess, that equates to about 20%
I dont think he will sell it at that price so it mute anyhow.
costs.
I was thinking you could have a fun summer flying to all the places that
worked on the airplane re-creating the logs.
Would this be as good as original if done?
thanks
James H. Macklin
ATP,CFI,A&P
can..
| BT
he lost the logs.
value of the plane.
Old January 25th 07, 05:02 PM posted to rec.aviation.piloting
You mean you'd still consider buying it without logbooks? The Seller is
doing nothing to re-create the logs? So aside from a pre-buy, you'd just
take the Seller's word for what has/hasn't been done and when? ... and
pay to have everything redone that requires signed/certified
documentation? Wow.
Old January 25th 07, 05:07 PM posted to rec.aviation.piloting
C J Campbell
On Thu, 25 Jan 2007 03:57:14 -0800, Lou wrote
(in article .com):
room.
checkride?
Lou
I have never seen a flight school keeping aircraft logbooks in a fireproof
safe. Usually these logbooks occupy several shelves in the maintenance office
and are much too large to put in any reasonable sort of safe.
Logbooks get lost, destroyed, or whatever, all of the time.
Waddling Eagle
World Famous Flight Instructor
Old January 25th 07, 05:09 PM posted to rec.aviation.piloting
C J Campbell
On Wed, 24 Jan 2007 20:04:33 -0800, Aluckyguess wrote
(in article ):
Unfortunately, there is no 'usual' amount. Either the logbooks are recreated
from maintenance and other records or you basically 'zero time' everything.
Logbooks do get lost or destroyed from time to time; there is no getting
around that. However, it does not render the aircraft valueless.
Waddling Eagle
Soaring Books Resource Paul Remde Soaring 1 August 14th 06 03:16 PM
hundreds aviation books for sale on CDs! centara Aviation Marketplace 0 March 1st 04 11:40 PM
Lost comms after radar vector Mike Ciholas Instrument Flight Rules 119 February 1st 04 12:39 AM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 04:09 AM
