Age of Ceconite?
Old January 29th 07, 08:45 PM posted to rec.aviation.piloting
Danny Deger
Default Age of Ceconite?
I am considering buying a Taylorcraft covered in Ceconite in 1993. An ideas
on how to make sure the fabric is in good shape? I don't want to have to
recover in the next couple of years.
Danny Deger
Old January 29th 07, 09:59 PM posted to rec.aviation.piloting
john smith
A punch test that any mechanic should know how to do will determine if
the fabric is still good.
Has the aircraft been hangared the whole time since it was covered?
Also of importance is the structure underneath. If you have steel tubing
beneath the fabric that was not properly treated before the covering
was applied and the aircraft has been out in the weather, a recovering
may be advised so that a proper inspection of the tubing can take place.
Old January 29th 07, 10:30 PM posted to rec.aviation.piloting
Ron Natalie
john smith wrote:
ideas on how to make sure the fabric is in good shape? I don't want
to have to recover in the next couple of years.
Any good mechanic would know that a punch test is not a valid test for
ceconite. As long as the finish remains intact, ceconite will last
indefinitely. You need to examine the visible parts of the condition:
finish, tapes, etc...
Old January 30th 07, 03:59 AM posted to rec.aviation.piloting
Carl Ellis
Danny Deger
Danny -
Go to vb.taylorcraft.org. Really good forum with lots of info.
- Carl -
Old January 30th 07, 04:50 AM posted to rec.aviation.piloting
Orval Fairbairn
Danny Deger
1. Is the plane hangared, or has it sat outside a lot?
2. If you take a drop light inside the fuselage or wing, can you see
light through the fabric? If so, it doesn't have enough silver and is
prone to UV damage.
3. What is the filler? Dope? Stits? Something else?
Old January 30th 07, 06:54 AM posted to rec.aviation.piloting
Jim Macklin
Have fabric samples taken from the critical areas, by a good
A&P/AI and send them in to be chemically and physically
laboratory tested. http://www.ceconite.com/manual.htm
General Aviation News
The Ceconite had a much longer life expectancy than
cotton or linen. Twenty years was not unusual when properly
applied, and rotting was virtually ...
generalaviationnews.com/editorial/articledetail.lasso?-token.key=323&-token.src=product&-nothing
- 45k - Cached - Similar pages
Aviation Safety Letter 2/2003
The life span of aircraft fabric is affected by its
exposure to the elements, ... It may be called Ceconite©,
Stits PolyFiber©, Nylon and other names but it ...
http://www.tc.gc.ca/civilaviation/Sy.../2-03/RA06.htm
- 45k -
"Orval Fairbairn" wrote in
message
news | In article ,
| Danny Deger
can you see
silver and is
| prone to UV damage.
Old January 30th 07, 05:10 PM posted to rec.aviation.piloting
Danny Deger
john smith wrote:
ideas on how to make sure the fabric is in good shape? I don't want to
I have heard the no punch rule on Ceconite also, but for the purpose of a
pre-buy inspection, wouldn't a punch test be a good idea? Also, without a
punch test how is an airplane known good to fly as far as the state of the
fabric is concerned. Even Ceconite after years in the sun will degrade --
want it? Can't you have an airplane with the tape all still together and
the paint still OK, but the underlying fabric is too weak?
Danny Deger
Emron over Ceconite process mhorowit Home Built 4 March 7th 06 10:33 PM
Is Ceconite and Peel Ply the same thing? Lou Home Built 9 January 14th 06 06:53 AM
Ceconite Wings Question Captain Wubba Owning 14 October 15th 04 08:55 PM
Ceconite v. Poly Fiber - Is one better than another?? DPB Restoration 4 May 17th 04 07:29 AM
