Went flying today. Go to crank the engine for start, nothing. Turn the
key, got like a jiggle of the prop. Turn all electrical things off, figuring the battery drained, and then started just the alt and bat, same thing, jiggle of the prop. Tried once more, and got the prop to turn and fired right up. Just had the durn starter replaced in July with a new one. I don't think it was the battery, as nothing moved when I turned the key, just a strange noise, no clicking like it would sound with a dead battery. When I fired up the master and alternator, I heard a noise sounding like something was draining the battery, yet the meter was stable in the middle, not indicating any discharge. Last week, when I cranked it, it struggled on the first turn of the prop, but it started, so I had attributed it to maybe my battery being low, it being very cold by MS standards, but after today, watching the electrical amnmeter, the load was fine once the engine was running. Am I having a bad run of starters, or should I be looking elsewhere for a problem? Grant you, I try to fly two times a week, but I would think I would have gotten more starts out of this starter then 6 months worth. Plane normally starts with one or two turns of the prop, so it's not like the starter is running for any period of time or been abused. Allen |
On Jan 29, 6:34 pm, A Lieberma wrote:
Went flying today. Go to crank the engine for start, nothing. Turn the key, got like a jiggle of the prop. Turn all electrical things off, figuring the battery drained, and then started just the alt and bat, same thing, jiggle of the prop. Tried once more, and got the prop to turn and fired right up. Just had the durn starter replaced in July with a new one. I don't think it was the battery, as nothing moved when I turned the key, just a strange noise, no clicking like it would sound with a dead battery. When I fired up the master and alternator, I heard a noise sounding like something was draining the battery, yet the meter was stable in the middle, not indicating any discharge. Last week, when I cranked it, it struggled on the first turn of the prop, but it started, so I had attributed it to maybe my battery being low, it being very cold by MS standards, but after today, watching the electrical amnmeter, the load was fine once the engine was running. Am I having a bad run of starters, or should I be looking elsewhere for a problem? Grant you, I try to fly two times a week, but I would think I would have gotten more starts out of this starter then 6 months worth. Plane normally starts with one or two turns of the prop, so it's not like the starter is running for any period of time or been abused. Allen Get a voltmeter and use the troubleshooting procedure outlined here... http://www.skytecair.com/images/Troubleshooting %20Diagram_5.0.pdf Could be a cable problem or something similar. Take the starter to an Autozone or similar store and have them test it for you (they can do the same for your alternator). Regards, Bud |
![]() wrote in message oups.com... : On Jan 29, 6:34 pm, A Lieberma wrote: : : : Get a voltmeter and use the troubleshooting procedure outlined here... : : http://www.skytecair.com/images/Troubleshooting : %20Diagram_5.0.pdf : : Could be a cable problem or something similar. Take the starter to an : Autozone or similar store and have them test it for you (they can do : the same for your alternator). : : Regards, : Bud : 1.66 megs: http://www.skytecair.com/images/Trou...iagram_5.0.pdf |
On Jan 30, 5:00 pm, "Blueskies" wrote:
wrote in ooglegroups.com... : On Jan 29, 6:34 pm, A Lieberma wrote: : : : Get a voltmeter and use the troubleshooting procedure outlined here... : : http://www.skytecair.com/images/Troubleshooting : %20Diagram_5.0.pdf : : Could be a cable problem or something similar. Take the starter to an : Autozone or similar store and have them test it for you (they can do : the same for your alternator). : : Regards, : Bud : 1.66 megs:http://www.skytecair.com/images/Trou...iagram_5.0.pdf Thanks for the re-post. Sorry about the wrap around URL. Bud |
![]() : Get a voltmeter and use the troubleshooting procedure outlined here... : : http://www.skytecair.com/images/Troubleshooting : %20Diagram_5.0.pdf The URL is mangled, but http://www.skytecair.com/Troubleshooting.htm gets you there. That's an excellent guide. Note they talk in #3 about measuring the difference between two terminals ***while under load.**** When not loaded, all will look fine... I'll add a few things. a) Watch out for the prop. b) In the steps showing you measuring at a terminal; there are THREE places to measu 1) The terminal bolt 2) The lug 3) The wire itself Assuming they are one & the same is a bad idea. If the lug-bolt connection is dirty, 1&2 will be different voltages UNDER LOAD. If the lug is not well-connected to the wire.... That's especially an issue with aluminum wire... Do not forget the grounds!! The battery ground, the engine-frame ground.... all those matter.. You can also diagnose bad starter connections another way -- feel. After the slow/failed crank, carefully feel each connection mentioned. The bad one will be hot, and may be HOT. The advantage to this is it is done after cranking, not while. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
![]() "A Lieberma" wrote in message . 18... Went flying today. Go to crank the engine for start, nothing. Turn the key, got like a jiggle of the prop. Turn all electrical things off, figuring the battery drained, and then started just the alt and bat, same thing, jiggle of the prop. Tried once more, and got the prop to turn and fired right up. Just had the durn starter replaced in July with a new one. I don't think it was the battery, as nothing moved when I turned the key, just a strange noise, no clicking like it would sound with a dead battery. When I fired up the master and alternator, I heard a noise sounding like something was draining the battery, yet the meter was stable in the middle, not indicating any discharge. Last week, when I cranked it, it struggled on the first turn of the prop, but it started, so I had attributed it to maybe my battery being low, it being very cold by MS standards, but after today, watching the electrical amnmeter, the load was fine once the engine was running. Am I having a bad run of starters, or should I be looking elsewhere for a problem? Grant you, I try to fly two times a week, but I would think I would have gotten more starts out of this starter then 6 months worth. Plane normally starts with one or two turns of the prop, so it's not like the starter is running for any period of time or been abused. Allen Check to make sure your engine is properly grounded to the airframe. Sometimes you get a loose connection, sometimes the connections corrode. In either case, the juice may try and find an alternate path, which can ruin throttle cables, P-leads, and other potential ground paths that are not sized for starter sized loads. KB |
"Kyle Boatright" wrote in
: Check to make sure your engine is properly grounded to the airframe. Sometimes you get a loose connection, sometimes the connections corrode. In either case, the juice may try and find an alternate path, which can ruin throttle cables, P-leads, and other potential ground paths that are not sized for starter sized loads. Thanks KB, From hearing noises in the headset when I switch on the master, my thoughts are it's a grounding or wiring problem. This was new on the last start, never heard any type of electrical noises. Will be sure to bring this up to my A&P. Allen |
What engine?
A Lieberma wrote: Went flying today. Go to crank the engine for start, nothing. Turn the key, got like a jiggle of the prop. Turn all electrical things off, figuring the battery drained, and then started just the alt and bat, same thing, jiggle of the prop. Tried once more, and got the prop to turn and fired right up. Just had the durn starter replaced in July with a new one. I don't think it was the battery, as nothing moved when I turned the key, just a strange noise, no clicking like it would sound with a dead battery. When I fired up the master and alternator, I heard a noise sounding like something was draining the battery, yet the meter was stable in the middle, not indicating any discharge. Last week, when I cranked it, it struggled on the first turn of the prop, but it started, so I had attributed it to maybe my battery being low, it being very cold by MS standards, but after today, watching the electrical amnmeter, the load was fine once the engine was running. Am I having a bad run of starters, or should I be looking elsewhere for a problem? Grant you, I try to fly two times a week, but I would think I would have gotten more starts out of this starter then 6 months worth. Plane normally starts with one or two turns of the prop, so it's not like the starter is running for any period of time or been abused. Allen |
Newps wrote in
: What engine? Lycoming AK4 360 in my 76 Beech Sundowner. Allen |
Lightweight Starter for Sale! | Tom Enterline | Home Built | 0 | July 4th 05 09:25 PM |
Stumped by new starter | Jim Burns | Owning | 16 | January 13th 05 03:42 PM |
Starter Questions | Aaron Coolidge | Owning | 4 | June 30th 04 02:52 PM |
Stuck starter solenoid? | Paul Lee | Home Built | 4 | April 16th 04 02:58 PM |
Starter selection -- seeking input | [email protected] | Owning | 3 | April 5th 04 12:43 AM |
