Stainless steel exhaust
Old February 12th 07, 11:08 PM posted to rec.aviation.homebuilt
headwind
Default Stainless steel exhaust
Aircraft Spruce has an exhaust for Pitts, AcroSport, etc. Has anyone
used it? If so, did it fit and do you recomend. It bolts to the engine
and has ball joints for 2 straight pipes. I plan to use on an
AcroSport with AEIO-320.
Headwind
Old February 13th 07, 06:30 AM posted to rec.aviation.homebuilt
Jerry Springer
Richard Riley wrote:
On 12 Feb 2007 14:08:20 -0800, "headwind"
Headwind
I haven't used theirs, but my experience with ss ball joints is poor.
They freeze after a couple of dozen hours. I've had much better luck
with slip joints.
I have been using exhaust with ball joints for years on my RV-6 and have
had no problems with sticking ball joints. Many of the RV builders use
these exhaust made by Larry Vetterman and sold by Van's aircraft and
from Larry . I do not have a number for him but here is info from Van's
http://tinyurl.com/2vzljd
IMO these are top quality exhausts.
Jerry
Old February 13th 07, 03:40 PM posted to rec.aviation.homebuilt
Stuart & Kathryn Fields
I've had the three bolt variety of exhaust ball joint on my 0320 powered
helicopter since 97 with no freeze up on any of them. They ain't cheap
though at $65 each.
Stuart Fields
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
(760) 408-9747 general and layout cell
(760) 608-1299 technical and advertising cell
www.vkss.com
www.experimentalhelo.com
"Jerry Springer" wrote in message
news:S1cAh.3084$ov2.1702@trndny06...
Headwind
with slip joints.
Jerry
Old February 13th 07, 07:49 PM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On Tue, 13 Feb 2007 06:40:17 -0800, "Stuart & Kathryn Fields"
though at $65 each.
Are the joints stainless?
Posted via a free Usenet account from http://www.teranews.com
Old February 14th 07, 04:30 AM posted to rec.aviation.homebuilt
Yep!
Stu Fields
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
www.vkss.com
clare at snyder.on.ca wrote in message
though at $65 each.
Stainless lines and fittings, free for the taking Richard Riley Home Built 4 May 7th 06 04:46 PM
nicopress sleeve for stainless steel cable ls Home Built 3 December 6th 05 05:09 PM
Working Stainless Steel Bob Babcock Home Built 7 February 14th 04 05:12 PM
structural stainless steel tank screws needed for PA-32-300 Dave Owning 11 October 1st 03 11:14 PM
37 degree flare, 1/8" stainless Richard Riley Home Built 8 August 29th 03 05:21 AM
