Is it safe/advisable to board a small single- or twin-engined aircraft while
the prop(s) and engine(s) are turning? I'm just wondering if this is feasible if you just have someone getting on or getting off (with the pilot being in the aircraft the whole time). On a related note, how long can you safely leave an aircraft (engines off) with just the parking brake set, and when do you normally put chocks under the wheels? -- Transpose mxsmanic and gmail to reach me by e-mail. |
I generally hit the pause button before getting out of the chair.
the prop(s) and engine(s) are turning? I'm just wondering if this is feasible if you just have someone getting on or getting off (with the pilot being in the aircraft the whole time). Advisable? No. Safe? Depends on too many factors to tell say outright... Front engined aircraft that boards over the trailing edge of the wing? Probably safe (although I'd imagine getting some doors open under even an idle prop-stream would be a pain/might risk damage to the door... light aircraft doors tend to be very flimsy) Twin which boards over the wing? Not a chance... WAY to many other variables (how bright is it (how visible is the prop disc), how much idle blast does the prop throw? Done anyways? Sure. On a related note, how long can you safely leave an aircraft (engines off) with just the parking brake set, Kinda a nonsensical question, how long until the next stiff wind blows? what angle will it blow at? In all honesty, most chalks will probably do no better than the wheel brakes alone at protecting from a stiff gust... t takes quite a bit of wind to overcome the static friction of the wheels. If the wind is strong enough to overpower a brake, a chalk probably won't do much better- what you'll need is good heavy chains, or better yet, a hangar. The flip-side is that in general, if your paying the MX bills, its really not a good idea to leave the brake engaged, this is simply a wear issue (Its better to store a hydrolic system unpressurized then pressurized, If you have the choice). Wheel chalks are slightly more reliable, and much cheaper, then a parking break, but no "safer" (better at keeping an aircraft stationary) and when do you normally put chocks under the wheels? when park your plane.... duh? |
"EridanMan" wrote when park your plane.... duh? Just for the uninformed, this is a troll,; a disturbed person that only flies microsoft flight simulator, and is afraid to get in a real airplane. He has problems with reality, and should be treated as a troll, and ignored. -- Jim in NC |
"Morgans" wrote in message
... "EridanMan" wrote when park your plane.... duh? Just for the uninformed, this is a troll,; a disturbed person that only flies microsoft flight simulator, and is afraid to get in a real airplane. He has problems with reality, and should be treated as a troll, and ignored. -- Jim in NC Ok, is there ANYONE here who isn't already familier with Mr. Maniac's background? Don't be shy - raise your hand. Anyone? Nope. I didn't think so. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Capt. Geoffrey Thorpe schrieb:
Ok, is there ANYONE here who isn't already familier with Mr. Maniac's background? Don't be shy - raise your hand. Anyone? Here! |
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:r5SdnXvx0KlcUX3YnZ2dnUVZ_vCknZ2d@wideopenwest .com... : : Ok, is there ANYONE here who isn't already familier with Mr. Maniac's : background? Don't be shy - raise your hand. : : Anyone? : : Nope. I didn't think so. : : -- : Geoff : The Sea Hawk at Wow Way d0t Com : remove spaces and make the obvious substitutions to reply by mail : When immigration is outlawed, only outlaws will immigrate. : : Who? |
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote Ok, is there ANYONE here who isn't already familier with Mr. Maniac's background? Don't be shy - raise your hand. Anyone? Nope. I didn't think so. This poster was a name I didn't recall seeing around, and I thought he was a newbie that needed to be informed. A thousand pardons, if that was not the case. -- Jim in NC |
On Feb 24, 4:13 pm, "Morgans" wrote:
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote Ok, is there ANYONE here who isn't already familier with Mr. Maniac's background? Don't be shy - raise your hand. Anyone? Nope. I didn't think so. This poster was a name I didn't recall seeing around, and I thought he was a newbie that needed to be informed. A thousand pardons, if that was not the case. -- Jim in NC I'm a lurker/occasional poster... I honestly had not understood what a lot of the problem with MX was until I read Jay's thread about loosing a friend while flying a few hours after posting this response to him. (I don't read every thread on this board) I'm not sure if I would still categorize him as a Troll in the strictest sense (not that Trollish behavior isn't a very subjective judgment). I've always considered Trolls to be posters who intentionally 'stir the pot' to see the emotional reaction without truly caring about the subject matter. MX on the other hand seems genuinely interested in flying and aviation, but otherwise fairly oblivious to how tactless and sophomoric his arguments can sound to others... To be completely honest, I suspect that MX is either a child or autistic adult- clearly intelligent and proud of his knowledge, but also completely oblivious socially/empathically and a little to eager to 'show off what he knows'. I think it would be hard to argue that he hadn't stirred up at least some reasonably interesting threads on this board... But I can understand those of you who are sick of it... I'm sorry, I will try and remember to use the MX: subject tag if/when I respond to him in the future. |
Morgans schrieb:
Just for the uninformed, this is a troll definition? :-) Andreas P.S. Get'n fed up with this on r.a.p! |
| Thread Tools | |
| Display Modes | |
| Medical running out? | [email protected] | Piloting | 6 | May 28th 06 03:19 PM |
| Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 04:47 PM |
| Running runup? | G. Burkhart | Piloting | 39 | July 7th 04 12:25 PM |
| Running an 0-235 well beyond TBO | Paul Folbrecht | Owning | 8 | March 14th 04 01:30 AM |
| Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 04:46 AM |
