Raw data of NWS winds aloft plots
Old March 5th 07, 04:15 AM posted to rec.aviation.piloting
Andrew Sarangan
Default Raw data of NWS winds aloft plots
Does anyone know if it is possible to access the raw data that is used
for the winds aloft plots on aviationweather.gov? At first I assumed
it was an interpolation of the classical FD text data. But then I
realized that the graphical plots have a finer time increment than the
FD text data. It is quite possible that they might be interpolating in
space and time, but I would like to know if there is another data set
that I am not aware of.
Old March 5th 07, 08:04 AM posted to rec.aviation.piloting
used for the winds aloft plots on aviationweather.gov?
The NWS has a lot of data available via FTP (see
http://www.nws.noaa.gov/tg/dataprod.html ) but from a quick look I
don't _think_ the winds aloft data is included.
The NWS also has wind profilers - basically radars that sit on the
ground and point straight up all the time. These give observed winds,
not forecast winds. Also, they don't cover the whole country, but
might be useful if you happen to be near one of the profilers. Plots
of the profiler data are available at
http://www.profiler.noaa.gov/npn/profiler.jsp .
It is quite possible that they might be interpolating in space and
time, but I would like to know if there is another data set that I
am not aware of.
In the past, I have gotten timely responses from the NWS by using the
"contact us" email links that are usually on their pages.
Matt Roberds
Old March 5th 07, 08:33 AM posted to rec.aviation.piloting
yuval
You can find it he
http://weather.uwyo.edu/upperair/sounding.html
Good Luck,
Yuval
Flight Data recorders on a 757 - What data? Al Dykes General Aviation 0 January 1st 07 05:09 PM
Clarity Aloft Question [email protected] Piloting 2 December 12th 05 06:46 PM
Proposed new user interface for winds and temperature aloft at ADDS Peter R. Piloting 0 May 25th 05 01:20 PM
Winds aloft = FD or FB? Andrew Sarangan Piloting 2 April 17th 05 02:21 PM
Nov 23 1400Z PWM winds aloft needed Roger Long Piloting 2 November 24th 03 04:12 AM
