I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube,
with a tight bend radius, no more than 3 inches. Can I do the bend hot without wrinkling the tube by free bending or do I need a supporting die of some kind? Anybody have any specific techniques? John |
"J.Kahn" wrote in message .. . I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube, with a tight bend radius, no more than 3 inches. Can I do the bend hot without wrinkling the tube by free bending or do I need a supporting die of some kind? Anybody have any specific techniques? Good luck, without a die bender. I have heard of some people bending tube by packing it, very tight, with sand. I have never done it, personally. -- Jim in NC |
John ..........
It has been close to fifty years since I spent my days in the pipe shop at Todd's Seattle, but memory serves well on this subject. It will be next to impossible to make those bends without a bender having and internal stretch die, or "bullet". Tubing with that thin of a wall and making that radius guarantees wrinkles. Packing it with sand will help, of course. There are low-temperature alloys with which you can fill the tube and then bend it cold. You heat the alloy, pour it in the tube, and then melt it out later. This is a clumsy operation and you may still wrinkle the tube. I would take it to a pro with the right machine. If you pack it with sand, put a wooden cork in one end of a long tube - the longer the better. Stand it vertical, fill with fine, dry sand and then spend an hour or so beating on the tube with a wooden hammer to pack the sand. Start at the bottom and work your way to the top, refilling as necessary. When you reach the top, smash in another plug, further compressing the sand. We had a 20' hole in the floor of the shop with a hoist overhead. There were three "rivet" hammers mounted to tap the pipe. We would very slowly lower the pipe past the rivet hammers. After an afternoon of constant rivet hammers, take a handful of aspirin. If you end up with wrinkles, they may be artfully removed with a torch and hammer, but it is difficult to do and requires much practice. Regards, Rich S. "J.Kahn" wrote in message .. . I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube, with a tight bend radius, no more than 3 inches. Can I do the bend hot without wrinkling the tube by free bending or do I need a supporting die of some kind? Anybody have any specific techniques? John |
Morgans wrote:
"J.Kahn" wrote in message .. . I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube, with a tight bend radius, no more than 3 inches. Can I do the bend hot without wrinkling the tube by free bending or do I need a supporting die of some kind? Anybody have any specific techniques? Fill the tube with water and freeze it. Bend it with the ice inside, this will help keep it from collapsing. It's better than trying to use sand and cheaper than low temperature metals. |
"J.Kahn" wrote in message .. . I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube, with a tight bend radius, no more than 3 inches. Can I do the bend hot without wrinkling the tube by free bending or do I need a supporting die of some kind? Anybody have any specific techniques? John I think I would try slipping a tension spring inside the tube if you can find one the right size. A 5/8" o.d. might be close enough, it would leave about .025" depending on how close the tube and the spring are to actual size. Also, I think a 3/4" electrical conduit bender will give you about a 4" radius, depending on brand. If that doesn't work, you might try making a square shouldered bending shoe out of 3/4" plywood for a tube that thin. Don't know for sure, just a wag. Thirty degrees isn't very far. Max |
Dennis Fetters wrote:
Morgans wrote: "J.Kahn" wrote in message .. . I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube, with a tight bend radius, no more than 3 inches. Can I do the bend hot without wrinkling the tube by free bending or do I need a supporting die of some kind? Anybody have any specific techniques? Fill the tube with water and freeze it. Bend it with the ice inside, this will help keep it from collapsing. It's better than trying to use sand and cheaper than low temperature metals. I'll experiment with that. Thanks. Doesn't the ice tend to crumble at the bend and loose its ability to support the tube? What about welding caps on the ends of the raw tube, one cap with a treaded hole to take a plug, then filling with water that's had all the air bubbles removed and plugging? John |
"Maxwell" wrote in message ... "J.Kahn" wrote in message .. . I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube, with a tight bend radius, no more than 3 inches. Can I do the bend hot without wrinkling the tube by free bending or do I need a supporting die of some kind? Anybody have any specific techniques? John I think I would try slipping a tension spring inside the tube if you can find one the right size. A 5/8" o.d. might be close enough, it would leave about .025" depending on how close the tube and the spring are to actual size. Also, I think a 3/4" electrical conduit bender will give you about a 4" radius, depending on brand. If that doesn't work, you might try making a square shouldered bending shoe out of 3/4" plywood for a tube that thin. Don't know for sure, just a wag. Thirty degrees isn't very far. Max Come to think of it, you might be able to wrap another spring around the outside, and go 30 degrees without a benging shoe. But obviously I'm still guessing. *Nothing is too difficult for the man that doesn't have to actually do it.* |
J.Kahn wrote: I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube, with a tight bend radius, no more than 3 inches. Can I do the bend hot without wrinkling the tube by free bending or do I need a supporting die of some kind? Anybody have any specific techniques? John John, They make special heavy springs which fit inside tubes to support the inside radius of the bend and keep it from collapsing when you bend it. Pulling on the spring causes its outside diameter to get slightly smaller so that you can get it out of the bent tube after you're done. Check at automotive parts stores and Harbor Freight. Good luck with it, Don W. |
J.Kahn wrote:
I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube, with a tight bend radius, no more than 3 inches. Can I do the bend hot without wrinkling the tube by free bending or do I need a supporting die of some kind? Anybody have any specific techniques? John --I bent some of the same tube by filling it with sand, bending it around a 10" pulley that had been turned out inside to 3/8" radius--Pulling it around with the inner race of a big ball brg that had used 3/4" balls--this was pressed onto a smaller brg which was bolted to a bar that pivoted on the center support of the pulley. BUT-- that's a 5" radius & you want 3"---might do it though..send ya a pic if your interested. wass biplane at tds dot net |
On Mar 5, 2:29 pm, Jerry Wass wrote:
J.Kahn wrote: I need to make bends of about 30 degrees in a 3/4 x .049 longeron tube, with a tight bend radius, no more than 3 inches. Can I do the bend hot without wrinkling the tube by free bending or do I need a supporting die of some kind? Anybody have any specific techniques? John --I bent some of the same tube by filling it with sand, bending it around a 10" pulley that had been turned out inside to 3/8" radius--Pulling it around with the inner race of a big ball brg that had used 3/4" balls--this was pressed onto a smaller brg which was bolted to a bar that pivoted on the center support of the pulley. BUT-- that's a 5" radius & you want 3"---might do it though..send ya a pic if your interested. wass biplane at tds dot net Can't you use a conduit bender? Lou |
| Thread Tools | |
| Display Modes | |
| Bending graphlite rod | [email protected] | Home Built | 15 | July 25th 06 07:43 AM |
| Bending sheet stock | Michael Horowitz | Restoration | 1 | April 24th 06 05:28 AM |
| Wing Bending Oscillation | jcarlyle | Soaring | 18 | February 21st 06 05:37 PM |
| Bending extruded angle | Veeduber | Home Built | 8 | August 29th 04 01:58 AM |
| Building the Po' Boy Bending Brake | Veeduber | Home Built | 14 | March 1st 04 07:15 PM |
