Like heat shrink tubing but not a tube.
Old March 28th 07, 04:20 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Default Like heat shrink tubing but not a tube.
I need to do what heat shrink tubing would be perfect for but I can't use
the HST because the end of what I need to cover is too large. Is there an
equivalent that will allow me to wrap the item and then heat shrink it?
Old March 28th 07, 04:23 PM posted to rec.aviation.homebuilt
John Ammeter
How big is what you have to cover? When I worked at the local electric
utility we had heat shrink tubing that was 4 inches in diameter before
being shrunk. I used some of it to cover wrench handles...
Old March 28th 07, 06:04 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
electric utility we had heat shrink tubing that was 4 inches in
diameter before being shrunk. I used some of it to cover wrench
handles...
can't use the HST because the end of what I need to cover is too
large. Is there an equivalent that will allow me to wrap the item
About the size of a pencil. Will the 4 inch stuff shrink down that much?
Old March 28th 07, 06:09 PM posted to rec.aviation.homebuilt
John Ammeter
They had all sizes to fit anything from 2" in diameter down to 1/4"...
stop by your local electric utility and ask to talk to the warehouse
supplier foreman. Don't bother calling because the "company" line will
be to say they can't/won't give out any items. The guy in the warehouse
will be much more cooperative. Explain your needs and ask nicely for
his help.
John
handles...
Old March 28th 07, 07:30 PM posted to rec.aviation.homebuilt
RST Engineering
Almost all shrink sleeving that I am aware of works on the 50% rule. That
is, it will shrink to 50% of its cold diameter. 4" will shrink to 2".
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message
Old March 28th 07, 08:04 PM posted to rec.aviation.homebuilt
Gene Seibel
On Mar 28, 8:20 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
20 years ago I worked at a TV station where we had a heat shrink tape
that we used to repair camera cables and such. It was like a thick
electrical tape that you'd wrap and then heat to shrink. However I
can't seem to find anything on the internet today. ????
Gene Seibel KB0NNN
http://pad39a.com/gene/broadcast.html
Because I fly, I envy no one.
Old March 28th 07, 08:05 PM posted to rec.aviation.homebuilt
Maxwell
handles...
I don't think anyone makes a heat shrink that with support that much
variation. Have you considered a product like *Dip-It* (sp). It is made for
coating tool handles, and is sold by a lot of hardware stores. I guess it
depends on what you are doing with it.
Old March 28th 07, 08:08 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Something like that is exactly what I'm looking for.
Old March 28th 07, 08:09 PM posted to rec.aviation.homebuilt
Dan Youngquist
On Wed, 28 Mar 2007, it was written:
I have heat shrink tubing from tiny up to 1" diameter, that I mail ordered
from Harbor Freight. And I have some 2" stuff a friend gave me; I don't
know its source. I would think any electronic parts shop (local or
online) would have at least up to 1" or so.
-Dan
Old March 28th 07, 08:12 PM posted to rec.aviation.homebuilt
Gene Seibel
On Mar 28, 12:08 pm, "Gig 601XL Builder"
Here's one that doesn't use heat
http://dkc3.digikey.com/PDF/T071/1793.pdf
Gene Seibel
Hangar 131 - http://pad39a.com/gene/plane.html
Relesable instrument tubing [email protected] Soaring 6 February 13th 07 06:38 AM
pvc tubing/sleeve source? Jim Burns Owning 4 September 28th 06 04:36 AM
pvc tubing/sleeve source? Jim Burns Home Built 4 September 28th 06 04:36 AM
Gauge of tubing??? Michael Horowitz Home Built 7 June 6th 06 02:32 PM
Tubing strength Ernest Christley Home Built 0 January 17th 04 12:43 AM
