Anybody know any tricks to removing the 3M type stick
on contest numbers that have been on for a while? Roy |
I've just used a hair dryer to warm it up and then peel it off. Auto paint
stores supply rubber wheels that 'erase' film trim. Either should do the job. Bill Daniels "Roy Bourgeois" wrote in message ... Anybody know any tricks to removing the 3M type stick on contest numbers that have been on for a while? Roy |
When using a hair dryer or especially a heat gun, don't use so much heat
that the tape film you are removing starts to melt or becomes weak. Sometimes pulling more slowly or at a different angle helps if the pull speed you are using is leaving adhesive on the surface or is breaking the tape. Conversely, sometimes pulling a sticker off quickly brings the adhesive off cleanly, while pulling slowly leaves residue behind - - experiment. If there is adhesive left on the surface, before using solvents try removing the adhesive with some tape. I've found cloth tape (with rubber adhesive) works well for this. Smooth the tape down and then pull straight off holding both ends of a short piece of tape. Repeat. bumper "Bill Daniels" bildan@comcast-dot-net wrote in message ... I've just used a hair dryer to warm it up and then peel it off. Auto paint stores supply rubber wheels that 'erase' film trim. Either should do the job. Bill Daniels "Roy Bourgeois" wrote in message ... Anybody know any tricks to removing the 3M type stick on contest numbers that have been on for a while? Roy |
bumper wrote:
When using a hair dryer or especially a heat gun, don't use so much heat that the tape film you are removing starts to melt or becomes weak. Sometimes pulling more slowly or at a different angle helps if the pull speed you are using is leaving adhesive on the surface or is breaking the tape. Conversely, sometimes pulling a sticker off quickly brings the adhesive off cleanly, while pulling slowly leaves residue behind - - experiment. If there is adhesive left on the surface, before using solvents try removing the adhesive with some tape. I've found cloth tape (with rubber adhesive) works well for this. Smooth the tape down and then pull straight off holding both ends of a short piece of tape. Repeat. bumper "Bill Daniels" bildan@comcast-dot-net wrote in message ... I've just used a hair dryer to warm it up and then peel it off. Auto paint stores supply rubber wheels that 'erase' film trim. Either should do the job. Bill Daniels "Roy Bourgeois" wrote in message ... Anybody know any tricks to removing the 3M type stick on contest numbers that have been on for a while? Roy WD-40 does a good job on some residual adhesives as well. |
bumper wrote:
When using a hair dryer or especially a heat gun, don't use so much heat that the tape film you are removing starts to melt or becomes weak. Sometimes pulling more slowly or at a different angle helps if the pull speed you are using is leaving adhesive on the surface or is breaking the tape. Conversely, sometimes pulling a sticker off quickly brings the adhesive off cleanly, while pulling slowly leaves residue behind - - experiment. Point the heat gun at the separation point from the adhesive side. If you peel at a reasonable rate the glass skin doesn't get more than body heat warm. I once tried using the gun on the other side, thinking that it would pre-soften the adhesive before it got peeled off. Doesn't work. The only effect was that the vinyl sheet got very soft and kept breaking. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
| Thread Tools | |
| Display Modes | |
| Removal of back seat? | Frode Berg | Owning | 10 | May 10th 06 05:48 AM |
| Adhesive removal | [email protected] | Soaring | 8 | May 2nd 06 03:37 PM |
| Pitts Number 1 registration number | Mirco | Aerobatics | 3 | December 4th 04 12:50 PM |
| PA28 140 starter removal | George Hamilton | Owning | 2 | October 31st 04 06:07 PM |
| Radio Removal | MRQB | Owning | 14 | March 25th 04 12:30 AM |
