Temporarily deviating from IFR
Old April 10th 07, 08:49 PM posted to rec.aviation.ifr,rec.aviation.piloting
Mxsmanic
Default Temporarily deviating from IFR
You're flying happily over the desert in your small plane, in bright, clear
weather, on your IFR flight plan. You notice a plume of smoke a short
distance away at your nine o'clock, and looking more carefully, you see what
looks like a stranded car with some people standing around it. You'd like to
investigate just to see if it might be someone who needs help.
Given that you're on an IFR flight plan and under ATC control, how do you
handle this? I presume you can't just tell ATC that you're going to swing
south and drop to 2000 feet for a while to check something out. Do you ask
ATC to vector you towards the stranded car? Do you cancel IFR to go take a
look? Is there a way of suspending IFR temporarily so that you can leave your
planned route and altitude and check out the source of the smoke? What's the
procedure?
On a related note (whence the crosspost to r.a.p.), has this ever happened to
you? That is, have you ever seen something that looked like a possible case
of people in distress on the ground and decided to go over and take a look
and/or report it to ATC?
Old April 10th 07, 08:57 PM posted to rec.aviation.ifr,rec.aviation.piloting
Newps
procedure?
Sure, you can....well nevermind.
Old April 11th 07, 12:44 AM posted to rec.aviation.ifr,rec.aviation.piloting
Al G[_1_]
"Newps" wrote in message
clear
what
like to
swing
ask
a
your
procedure?
happened to
case
look
Oh Yea, the old "Burning Car in the Desert" trick.
Al G
Old April 10th 07, 08:56 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
clear weather, on your IFR flight plan. You notice a plume of smoke a
short distance away at your nine o'clock, and looking more carefully,
you see what looks like a stranded car with some people standing
around it. You'd like to investigate just to see if it might be
you handle this? I presume you can't just tell ATC that you're going
to swing south and drop to 2000 feet for a while to check something
out. Do you ask ATC to vector you towards the stranded car? Do you
cancel IFR to go take a look? Is there a way of suspending IFR
temporarily so that you can leave your planned route and altitude and
check out the source of the smoke? What's the procedure?
happened to you? That is, have you ever seen something that looked
like a possible case of people in distress on the ground and decided
to go over and take a look and/or report it to ATC?
Yep, happened to me. I saw a ship spewing oil. I went closer (IFR in an
airliner, yet) to have a look.
Semd me 100$ and I'll tell you how it all worked.
Bertie
Old April 10th 07, 09:25 PM posted to rec.aviation.piloting
gpaleo
Why don't you ever stop??
You've had you fun with the group, do something constructive for yourself,
instead of wasting away laughing your ass off with us.
Shoo.
Go away.
Do something else.
Shoo.
Old April 10th 07, 10:41 PM posted to rec.aviation.ifr,rec.aviation.piloting
Danny Deger
"Mxsmanic" wrote in message
clear
what
to
Simple -- request deviations in the direction needed by the distance needed,
request an altitude block, and request the correct number of 360 degree
turns.
The call would be something like, "Request deviation 10 miles north of
course, altitude block of 2,000 to 3,000 feet and 3 360s to investegate a
possible car in distress." But, if the weather is VFR, "Cancel IFR" might
be the best call.
Danny Deger
ask
a
your
procedure?
to
case
Old April 10th 07, 10:08 PM posted to rec.aviation.ifr,rec.aviation.piloting
Mxsmanic
Danny Deger writes:
be the best call.
Can you reactivate an IFR flight plan after cancelling it and continue from
some point within the plan, or do you have to file a brand new one if you want
to return to IFR.
I take it there's no such thing as "suspend IFR."
Old April 10th 07, 10:57 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Danny Deger writes:
of course, altitude block of 2,000 to 3,000 feet and 3 360s to
investegate a possible car in distress." But, if the weather is VFR,
"Cancel IFR" might be the best call.
from some point within the plan, or do you have to file a brand new
one if you want to return to IFR.
What's it to you? You'll never fly.
Bertie
Old April 11th 07, 12:03 AM posted to rec.aviation.ifr,rec.aviation.piloting
Danny Deger
Danny Deger writes:
might
be the best call.
from
want
to return to IFR.
You are correct. Once you cancel, you have to refile.
Danny Deger
Old April 11th 07, 12:37 AM posted to rec.aviation.ifr,rec.aviation.piloting
Jose
If you are VMC and expect to remain so, you could request "VFR on top"
and a course deviation. If they don't have to hold a hard altitude for
you, they may be more flexible in granting deviations.
Jose
Get high on gasoline: fly an airplane.
High Voltage Light On (Temporarily) three-eight-hotel Owning 15 April 28th 06 07:21 PM
FAA has temporarily withdrawn the proposed Sport Pilot rule Larry Dighera Piloting 2 March 27th 04 06:23 AM
Standard Cirrus web site temporarily offline Jim Hendrix Soaring 1 January 21st 04 07:09 PM
