brake fittings
Old April 27th 07, 07:41 AM posted to rec.aviation.homebuilt
Default brake fittings
Can I connect aluminum AN fittings to steel hose ends? I am
planning on using Earl's Speed-Flex hose with Speed-Seal hose ends on
my Avid Mark IV with Grove gear and Matco brakes. Will there be
corrosion
from the mating of dissimilar metals? Thanks.
Old April 27th 07, 02:52 PM posted to rec.aviation.homebuilt
stol
corrosion
I have the exact configuration on my Zenith 801 experimental. Been
that way for 4 years and I just finished my conditional inspection
this week. Virtually no sign of dissimilar metal corrosion... YMMV
Ben
www.haaspowerair.com
Old April 27th 07, 05:22 PM posted to rec.aviation.homebuilt
On Apr 27, 7:02 am, Orval Fairbairn wrote:
In article .com,
corrosion
Short answer: no problem.
Long answer:
Aluminum fittings are already corrosion-protected (either anodized or
some other treatment). In addition, there is usually a small amount of
oil or some other lubricant on the fitting, which stops water intrusion.
Not familiar with the Earl's hose ends. Are those for
aircraft or automotive? Aircraft fittings have a 37 degree flare,
autos have a 45 degree. Not compatible at all.
Dan
Pnuematic air line fittings? Michael Baldwin, Bruce Products 0 December 31st 06 11:41 AM
Brass Compression Fittings,Fittings for Pex-Al-Pex Sale on good price valvetom Piloting 0 November 27th 06 06:58 PM
AN Fittings Bruce A. Frank Home Built 4 May 6th 05 05:11 PM
Fuel pump fittings Evan Carew Home Built 15 October 3rd 04 04:13 AM
Need advice on Aeroquip fittings Corky Scott Home Built 2 December 12th 03 01:46 AM
