Looking ( yeh I know I have been looking a lot) at buying a Garmin GPS (
probably a 96C), and they have 2 types of external antenna, one has like a suction cup on it and the other has a magnet.). Just wondered what type is best and where the best place is to locate the antenna . I would have guessed the back window would have the least obstructed view, but then I have to run the cable from the yoke to the back window which sounds a bit messy. Will the front screen be OK? ( I am only a renter, so I cant lay any cables permanently). What do other folks here do with their antenna? I am a bit wary of the magnet idea in case it affects the compass ... I dont want to rely totally on GPS. terry |
You most likely don't need an external antenna. If you do it doesn't
need to attach to anything. Just run the cable up to the front of the windshield and set it there. If it wants to move push a small portion into the junction of the top of the panel and the windshield just forward of the pilots door. d&tm wrote: Looking ( yeh I know I have been looking a lot) at buying a Garmin GPS ( probably a 96C), and they have 2 types of external antenna, one has like a suction cup on it and the other has a magnet.). Just wondered what type is best and where the best place is to locate the antenna . I would have guessed the back window would have the least obstructed view, but then I have to run the cable from the yoke to the back window which sounds a bit messy. Will the front screen be OK? ( I am only a renter, so I cant lay any cables permanently). What do other folks here do with their antenna? I am a bit wary of the magnet idea in case it affects the compass ... I dont want to rely totally on GPS. terry |
"Newps" wrote in message . .. You most likely don't need an external antenna. If you do it doesn't need to attach to anything. Just run the cable up to the front of the windshield and set it there. If it wants to move push a small portion into the junction of the top of the panel and the windshield just forward of the pilots door. Thanks for the suggestio Newps . The reason I am buying a Garmin is because I had a lttle Magellan Map 330 which worked fine when I was flying a Warrior, but on about 3 occaisions flying a Cessna the signal dropped out. the consensus of advice I recieved was that the high wing blocked out the signal, and unfortunately the Magellan units dont have external antenna facility. terry |
I have a Garmin 296 which I use in rented C152s and C172s. I don't use an
outside antenna. I just put the GPS receiver on the dash of the aiplane (on a beanbag mount, which is temporary and works great) and use the little antenna on the GPS receiver. It works fine. I've never had any problems with reception. Martha "d&tm" wrote in message ... Looking ( yeh I know I have been looking a lot) at buying a Garmin GPS ( probably a 96C), and they have 2 types of external antenna, one has like a suction cup on it and the other has a magnet.). Just wondered what type is best and where the best place is to locate the antenna . I would have guessed the back window would have the least obstructed view, but then I have to run the cable from the yoke to the back window which sounds a bit messy. Will the front screen be OK? ( I am only a renter, so I cant lay any cables permanently). What do other folks here do with their antenna? I am a bit wary of the magnet idea in case it affects the compass ... I dont want to rely totally on GPS. terry |
On May 6, 4:56 pm, "Russ and/or Martha Oppenheim"
wrote: I have a Garmin 296 which I use in rented C152s and C172s. I don't use an outside antenna. I just put the GPS receiver on the dash of the aiplane (on a beanbag mount, which is temporary and works great) and use the little antenna on the GPS receiver. It works fine. I've never had any problems with reception. Martha "d&tm" wrote in message ... Looking ( yeh I know I have been looking a lot) at buying a Garmin GPS ( probably a 96C), and they have 2 types of external antenna, one has like a suction cup on it and the other has a magnet.). Just wondered what type is best and where the best place is to locate the antenna . I would have guessed the back window would have the least obstructed view, but then I have to run the cable from the yoke to the back window which sounds a bit messy. Will the front screen be OK? ( I am only a renter, so I cant lay any cables permanently). What do other folks here do with their antenna? I am a bit wary of the magnet idea in case it affects the compass ... I dont want to rely totally on GPS. terry- Hide quoted text - - Show quoted text - I have a 96C and have used it extensively in a 172N, and never had any problem at all with reception. With no need for an antenna and the HUGE battery life, you're completely cable free, and it's wonderful!! The bonus yoke mount isn't the best on our 172 though, the clamp is designed for a thicker tube on the backside of the yoke, but it still works, it's just not quite as firm as I would prefer. If you are tossing up between a 96 and a 96C, my advice is definitely get the 96C. Twice the battery life (40 hrs vs 20 hrs) and 5 times the memory. Oh, and the colour screen looks fabulous in bright sunlight, believe it or not!! |
"chris" wrote in message oups.com... On May 6, 4:56 pm, "Russ and/or Martha Oppenheim" wrote: I have a Garmin 296 which I use in rented C152s and C172s. I don't use an outside antenna. I just put the GPS receiver on the dash of the aiplane (on a beanbag mount, which is temporary and works great) and use the little antenna on the GPS receiver. It works fine. I've never had any problems with reception. Martha "d&tm" wrote in message ... Looking ( yeh I know I have been looking a lot) at buying a Garmin GPS ( probably a 96C), and they have 2 types of external antenna, one has like a suction cup on it and the other has a magnet.). Just wondered what type is best and where the best place is to locate the antenna . I would have guessed the back window would have the least obstructed view, but then I have to run the cable from the yoke to the back window which sounds a bit messy. Will the front screen be OK? ( I am only a renter, so I cant lay any cables permanently). What do other folks here do with their antenna? I am a bit wary of the magnet idea in case it affects the compass ... I dont want to rely totally on GPS. terry- Hide quoted text - - Show quoted text - I have a 96C and have used it extensively in a 172N, and never had any problem at all with reception. With no need for an antenna and the HUGE battery life, you're completely cable free, and it's wonderful!! The bonus yoke mount isn't the best on our 172 though, the clamp is designed for a thicker tube on the backside of the yoke, but it still works, it's just not quite as firm as I would prefer. If you are tossing up between a 96 and a 96C, my advice is definitely get the 96C. Twice the battery life (40 hrs vs 20 hrs) and 5 times the memory. Oh, and the colour screen looks fabulous in bright sunlight, believe it or not!! Thanks for the advice Chris. You have convinced me. The 96C it is! terry |
"Russ and/or Martha Oppenheim" wrote in message ... I have a Garmin 296 which I use in rented C152s and C172s. I don't use an outside antenna. I just put the GPS receiver on the dash of the aiplane (on a beanbag mount, which is temporary and works great) and use the little antenna on the GPS receiver. It works fine. I've never had any problems with reception. Martha Thanks Martha, thats very useful to know, perhaps in hindsight the problem I had with the magellan was I just had it sitting on the pax seat ( which was always fine in the warrior) perhaps if I put it on the dash in the cessna it would be OK. I have decided to go for a garmin 96C anyway because I want the aviation data base. terry |
On May 8, 8:50 am, "d&tm" wrote:
"chris" wrote in message oups.com... On May 6, 4:56 pm, "Russ and/or Martha Oppenheim" wrote: I have a Garmin 296 which I use in rented C152s and C172s. I don't use an outside antenna. I just put the GPS receiver on the dash of the aiplane (on a beanbag mount, which is temporary and works great) and use the little antenna on the GPS receiver. It works fine. I've never had any problems with reception. Martha "d&tm" wrote in message ... Looking ( yeh I know I have been looking a lot) at buying a Garmin GPS ( probably a 96C), and they have 2 types of external antenna, one has like a suction cup on it and the other has a magnet.). Just wondered what type is best and where the best place is to locate the antenna . I would have guessed the back window would have the least obstructed view, but then I have to run the cable from the yoke to the back window which sounds a bit messy. Will the front screen be OK? ( I am only a renter, so I cant lay any cables permanently). What do other folks here do with their antenna? I am a bit wary of the magnet idea in case it affects the compass ... I dont want to rely totally on GPS. terry- Hide quoted text - - Show quoted text - I have a 96C and have used it extensively in a 172N, and never had any problem at all with reception. With no need for an antenna and the HUGE battery life, you're completely cable free, and it's wonderful!! The bonus yoke mount isn't the best on our 172 though, the clamp is designed for a thicker tube on the backside of the yoke, but it still works, it's just not quite as firm as I would prefer. If you are tossing up between a 96 and a 96C, my advice is definitely get the 96C. Twice the battery life (40 hrs vs 20 hrs) and 5 times the memory. Oh, and the colour screen looks fabulous in bright sunlight, believe it or not!! Thanks for the advice Chris. You have convinced me. The 96C it is! terry- Hide quoted text - - Show quoted text - No worries!! It also comes with a free yoke mount which takes less than a minute to install and remove, and puts it right in front of you and with good amounts of windshield above it for excellent satellite reception. I just remembered that a friend was in the back seat of our Arrow the other day and couldn't get reception on his iPaq GPS with external antenna but it works fine attached to the yoke.. I think the 96C is just awesome for such a small unit, for what it can do! I use a Mac and download my tracks after each flight and can analyse track plus alt + speed, it's really good! |
| Thread Tools | |
| Display Modes | |
| Garmin 95 antenna needed | Marty from Florida | Owning | 0 | February 19th 06 09:48 PM |
| Garmin remote antenna | Dave | Piloting | 3 | December 18th 05 12:58 PM |
| Many manuals and POH for auction, C402B, C177RG, C172, Garmin 300xl | E-man | Piloting | 0 | December 15th 05 04:08 AM |
| FS '77 C152 | Darrel Toepfer | Aviation Marketplace | 6 | June 19th 04 03:20 AM |
| Garmin Emap Handheld GPS w/ Remote Antenna AND Data Transfer Cable | Cecil E. Chapman | Products | 0 | October 1st 03 03:06 AM |
