Steel prep for two part epoxy?
Old May 12th 07, 02:15 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Steel prep for two part epoxy?
I have yet to decide what epoxy to use on my steel fuselage, so I have
no literature on how to prep the metal.
Part of my decision making is _where_ to do the work. If I have to use
MEK or like solvent, I don't want to do the work in a semi-enclosed
area; if a dry wipe-down or alchol is sufficient, then my work-place
of choice is OK.
Assuming I"ve brought to fuselage back to bare metal and have used
emery cloth so there exists a 'tooth' to the metal, does metal prep
require the use of MEK or acytone prior to primer application? - Mike
Old May 12th 07, 05:36 PM posted to rec.aviation.homebuilt
Orval Fairbairn
of choice is OK.
For steel (or any metal, for that matter), you have to remove all
oils/greases. A wipe down with lacquer thinner, MEK, alcohol, etc. will
do this. Look for a clean-looking cloth or paper towel.
You should also remove any welding scale, which consists of oxides of
iron before priming. This process usually involves fine-particulate
(glass beads are best) blasting of welded areas to clean the metal.
As soon as the metal is clean, apply two-part epoxy primers. Wear
appropriate breathing protection, as the stuff is cumulatively toxic and
allergenic.
Old May 12th 07, 06:00 PM posted to rec.aviation.homebuilt
Clay
Wear good quality gloves which are resistant to the chemicals you will
be using.
I would not use alcohol because it contains water. The water in the
alcohol can cause flash rusting.
Acetone is a little kinder to the body than MEK. MEK and Acetone are
both flammable, so be careful.
Orval has given very sound advise. Wear eye protection.
Old May 12th 07, 06:02 PM posted to rec.aviation.homebuilt
Maxwell
"Michael Horowitz" wrote in message
of choice is OK.
I would suggest a stainless steel rotary brush and a high speed grinder, if
you can't bead blast the weld areas. Clean the areas to be brushed thououghy
with MEK or acetone before brushing, and clean the brush often in MEK or
acetone, to avoid spreading any oil or grease.
Change wiping cloths or paper towels often to avoid any build up in your
cloth.
Old May 13th 07, 06:38 PM posted to rec.aviation.homebuilt
Michelle P
of choice is OK.
Bare metal. Abrasive then wipe with denatured alcohol, Acetone or MEK
depending on if anything is left. They are all in the same family.
Alcohol being the mildest and MEK the strongest.
Nitrile glove are a must for all phases of the prep. Respirator is a
good idea as well. Eye protect is always a good idea.
Michelle
Old May 19th 07, 02:15 AM posted to rec.aviation.homebuilt
Ebby
After reading this I have a question for those who have gone through this
process. I have a freshley welded steel tube fuselage with no surface rust
at all. Is is necessary to sandblast the whole thing then prime or can I
use scuffs and emery with the stainless brush mentioned? Seems like media
blasting with sand or glass is a bit harsh for a new fuselage. What do they
do at maule? All that needs to be removed is the dark mill scale and epoxy,
from what I've heard will stick to almost anything.
"Ebby"
Hatz Classic s/n37
NY
"Michelle P" wrote in message
ink.net...
of choice is OK.
depending on if anything is left. They are all in the same family. Alcohol
Nitrile glove are a must for all phases of the prep. Respirator is a good
Michelle
Old May 19th 07, 04:52 AM posted to rec.aviation.homebuilt
Orval Fairbairn
I don't know what they do at Maule, but you need to have metal under the
epoxy -- not oxides of iron. Bead blasting the discolored areas around
the welds is a good way to remove any extraneous oxides that could crack
and attract water.
The most important part of the prep is to remove all traces of oils and
grease (including those from hands) before priming.
An airbrush is a good way to apply primer, as it has a narrow pattern
and will not waste too much expensive paint and primer.
Old May 20th 07, 06:32 AM posted to rec.aviation.homebuilt
Michelle P
"Ebby"
Hatz Classic s/n37
NY
ink.net...
of choice is OK.
Michelle
I have a powder coated airframe in my Maule. It is my understanding that
bright shiny metal is achieved before the coating is applied.
Michelle
Old May 21st 07, 03:55 AM posted to rec.aviation.homebuilt
Ebby
In anticipation of your answers I did a major spring clean of the garage
this weekend so I can set up a blasting/paint shop later on this summer. I
was just hoping I could get by without chewing into all that new metal. My
advisor at my EAA chapter tipped me off about using an airbrush. Hearing it
again helps. Thanks for the advice.
Ebby
link.net...
rust at all. Is is necessary to sandblast the whole thing then prime or
can I use scuffs and emery with the stainless brush mentioned? Seems
like media blasting with sand or glass is a bit harsh for a new fuselage.
What do they do at maule? All that needs to be removed is the dark mill
scale and epoxy, from what I've heard will stick to almost anything.
"Ebby"
Hatz Classic s/n37
NY
ink.net...
of choice is OK.
Michelle
Michelle
T-88 epoxy Lou Home Built 1 December 5th 06 12:15 AM
Epoxy for Fuel Tanks Doug Palmer Home Built 1 April 12th 06 03:53 AM
EPOXY GLUES minot piper e Restoration 0 January 30th 04 02:13 AM
epoxy aircraft seats? Lpmcatee356 Home Built 26 December 4th 03 12:16 AM
