Ipaqs batteries run down pretty quickly even when switched
off. If I unlock an hx4700 battery without removing it (by flicking the left hand battery lock switch on the base of the unit to the right) then unit seem to switch off fully allowing the main battery to stay charged. The back-up battery doesn't seem to run down over several days either. Is this common practice or are there any adverse consequences that I haven't yet encountered? John Galloway |
"John Galloway" wrote in message ... Ipaqs batteries run down pretty quickly even when switched off. If I unlock an hx4700 battery without removing it (by flicking the left hand battery lock switch on the base of the unit to the right) then unit seem to switch off fully allowing the main battery to stay charged. The back-up battery doesn't seem to run down over several days either. Is this common practice or are there any adverse consequences that I haven't yet encountered? John Galloway My hx4700 can go a couple of weeks without a charge even with occasional use (but not a gliding application). Are you sure that you're shutting down SeeYou, Winpilot or whatever you use? I'm told that leaving these running will drain the batteries because the serial port remains powered. On the other hand, perhaps your battery is past it's best. I'd be a bit cautious about relying on the standby battery. If that goes flat then it's a complete reload of applications and data. Stephen |
I read this posting and decided to test my hx4700. I usually leave it
plugged in. I turned it off my making sure no programs were running and then using the on/off button on the top right edge. After four days (since the original posting) the battery says it has 94% charge remaining. I think you have a bad battery or you are not really turning the unit off. Guy |
Thanks for the replies. I should have been clearer
in my original posting. I have 2 hx4700s, both with good batteries and regularly backed up on SD cards. I have no day to day problem with them going flat and usually keep the main on charge between flights and the back-up on charge permanently. I noticed by chance that if the left battery catch is unlocked that they seem to stop using power completely. I have been leaving one like that for the last 10 days or so and have just powered it up to check and both main and back-up batteries are reading 100% charge. On powering up they seem to do a soft reset (I think) but all settings are saved as far as I can see. I am not sure exactly what state they are in with the battery unlocked but they don't seem to drain the back-up battery - so far. John Galloway At 12:18 16 May 2007, wrote: I read this posting and decided to test my hx4700. I usually leave it plugged in. I turned it off my making sure no programs were running and then using the on/off button on the top right edge. After four days (since the original posting) the battery says it has 94% charge remaining. I think you have a bad battery or you are not really turning the unit off. Guy |
| Thread Tools | |
| Display Modes | |
| IPAQ 4700/4705 | Doug LS4 | Soaring | 9 | January 31st 06 02:01 PM |
| New iPAQ 4700 | Paul Remde | Soaring | 2 | October 10th 04 12:06 AM |
| risky storage? | R.Hubbell | General Aviation | 3 | February 11th 04 08:17 AM |
| Battery storage? | Roger Long | Owning | 10 | January 14th 04 03:35 PM |
| 103 Storage | BTIZ | Soaring | 3 | November 18th 03 01:47 AM |
