Tubercles lower stalling airspeed?
Old May 14th 07, 05:13 PM posted to rec.aviation.soaring
RichardFreytag
Default Tubercles lower stalling airspeed?
This article: http://www.thestar.com/Business/article/213475
claims that the tuburcles on the leading edge of whale fins actually
improve efficiency in fluid by lowering stall speed. I expect someone
here might have a good sense if this has any likelihood of working.
Old May 14th 07, 05:37 PM posted to rec.aviation.soaring
bumper
"RichardFreytag" wrote in message
I'm not so sure, Richard. I remember about a decade ago there was an
independent double-blind study done on the aerodynamics of humpback whales.
Best they could achieve was an L/D of about 0/1 when dropped from 10,000
feet.
bumper
Minden, NV
ZZ
Old May 14th 07, 05:55 PM posted to rec.aviation.soaring
This article:http://www.thestar.com/Business/article/213475
feet.
bumper
Minden, NV
ZZ
As I recall pretty much came out about the same as a bowl of petunias.
Old May 14th 07, 11:12 PM posted to rec.aviation.soaring
Shawn[_3_]
This article:
feet.
bumper
Minden, NV
ZZ
Oh no, not again.
Old May 14th 07, 06:30 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
On Mon, 14 May 2007 16:37:06 GMT, "bumper"
feet.
But they did achieve a successful calibration of the Norden
Whalesight.
rj
Old May 14th 07, 08:14 PM posted to rec.aviation.soaring
Nyal Williams
Whale of a 'tail.'
At 17:30 14 May 2007, Ralph Jones wrote:
On Mon, 14 May 2007 16:37:06 GMT, 'bumper'
'RichardFreytag' wrote in message
roups.com...
fins actually
I expect someone
of working.
ago there was an
of humpback whales.
dropped from 10,000
feet.
Norden
Whalesight.
rj
Old May 15th 07, 04:47 PM posted to rec.aviation.soaring
Paul Repacholi
RichardFreytag writes:
Was worked on in the wind tunnel by one of the east coast US unis, Princton?,
and they got up to about a 28deg AoA with a perspex replica of a Humpback fin.
Old May 15th 07, 07:02 PM posted to rec.aviation.soaring
Bob Kuykendall
improve efficiency in fluid by lowering stall speed...
Lower the stall speed? Probably. I can see them having the same effect
as adding typical blade-type turbulators in that regard.
Improve efficiency? It depends on what your measure of efficiency is.
I strongly doubt that it could make any improvement in best L/D. My
guess would tend the other way. I'd reckon that sucker-punching your
boundary layer is a sure ticket for a trip through the weeds.
Thanks, Bob K.
http://www.hpaircraft.com/hp-24
Thermal Core Tip Stalling Derek Copeland Soaring 7 February 2nd 06 02:55 PM
Stalling and spinning generally Ian Strachan Soaring 0 February 1st 04 08:40 PM
Spinning or the after effects of stalling. Dave Martin Soaring 0 January 29th 04 11:24 PM
Wingdrop while stalling drake Home Built 28 January 17th 04 12:43 PM
Tow plane airspeed vs. glider being towed airspeed? MHende6388 Soaring 2 September 28th 03 09:35 AM
