I've been shopping for a plane for a while. I'm hoping I found the
one but the engine has given me pause. The engine is 17-years old. It has ~700 hours on it. The average per year is only 49hr/year. Two years during that 17, the plane did not fly and I'm guessing it was not pickled. The latest it sat was in 2000. During the last 6 years, the plane has mostly flown some 32hrs/year on average. The engine is a Ly IO-360-A1A. Compression on the engine is 74, 76, 74, 76. The owner refuses to negotiate on the basis of these concerns and leaves me nothing to mitigate some of the potential risk. I spoke with a local mechanic today and his opinion is that it should give pause but the engine may be fine and was seemingly encouraged by the compression numbers. He recommends an oil analysis. His opinion is the biggest potential unseen danger stems from the cam and an oil analysis would address this concern one way or the other. Comments? Would you consider such a deal? The mechanic's advice seem sound? Greg |
It's a Lycoming, compression is always good. You need to check the cam.
Lyc's lose their cams without use. Greg Copeland wrote: I've been shopping for a plane for a while. I'm hoping I found the one but the engine has given me pause. The engine is 17-years old. It has ~700 hours on it. The average per year is only 49hr/year. Two years during that 17, the plane did not fly and I'm guessing it was not pickled. The latest it sat was in 2000. During the last 6 years, the plane has mostly flown some 32hrs/year on average. The engine is a Ly IO-360-A1A. Compression on the engine is 74, 76, 74, 76. The owner refuses to negotiate on the basis of these concerns and leaves me nothing to mitigate some of the potential risk. I spoke with a local mechanic today and his opinion is that it should give pause but the engine may be fine and was seemingly encouraged by the compression numbers. He recommends an oil analysis. His opinion is the biggest potential unseen danger stems from the cam and an oil analysis would address this concern one way or the other. Comments? Would you consider such a deal? The mechanic's advice seem sound? Greg |
Newps wrote:
It's a Lycoming, compression is always good. You need to check the cam. Lyc's lose their cams without use. Believe me, the compressions were great on my engine up until the time the cylinder blew. As Newps says, you need to take a look inside. I'd particularly be worried about corrosion (cam and cyl) on an engine that flies infrequently. |
On 5/18/2007 8:22:50 PM, Greg Copeland wrote:
The owner refuses to negotiate on the basis of these concerns and leaves me nothing to mitigate some of the potential risk. With the glut of aircraft on the market I would suspect you will find a much less risky purchase. From what I have learned over the last six years as a single engine aircraft owner, I would walk away from this sale without a second thought. You have every right to be concerned about an engine that has seen such little use over such a long period of time. -- Peter |
On 18 May 2007 17:22:54 -0700, Greg Copeland wrote:
I've been shopping for a plane for a while. I'm hoping I found the one but the engine has given me pause. The engine is 17-years old. It has ~700 hours on it. The average per year is only 49hr/year. Two years during that 17, the plane did not fly and I'm guessing it was not pickled. The latest it sat was in 2000. During the last 6 years, the plane has mostly flown some 32hrs/year on average. The engine is a Ly IO-360-A1A. Compression on the engine is 74, 76, 74, 76. The owner refuses to negotiate on the basis of these concerns and leaves me nothing to mitigate some of the potential risk. I spoke with a local mechanic today and his opinion is that it should give pause but the engine may be fine and was seemingly encouraged by the compression numbers. He recommends an oil analysis. His opinion is the biggest potential unseen danger stems from the cam and an oil analysis would address this concern one way or the other. Comments? Would you consider such a deal? The mechanic's advice seem sound? Greg This really falls into the area of negotiating strategy rather than "would you buy this engine". In your position, I would figure out how much *I* thought the plane might be worth assuming the engine will require a complete overhaul, including accessories, fuel and oil lines, mounts, cooler overhaul, etc. Possibly a prop overhaul also? Or maybe the Hartzell prop hub needs to be replaced because of the new A/D? Then I would inform the seller how much I would be willing to pay for his aircraft. I would not necessarily go into any details as to how I arrived at that figure, although I might depending on the specifics of what happened next. It is the seller's right to ask whatever he wants for his airplane, and it is my right to not pay any more than I want to. But, if you run the numbers, you might discover that his asking price is such that you can live with it, even with overhauling the engine right after purchase. So far as oil analysis being able to predict whether a new cam will be required in the next 25 hours or so -- it won't. And I've flown behind a Lyc IO360A1A for the past 30 years or so, and gone through several camshafts during that time! FWIW, Lycoming recommends overhaul of that engine at 12 years, if it has not met the flight time limits. Of course, under Part 91 non-commercial flying, it is perfectly *legal* to overhaul "on-condition". But I would only purchase that aircraft assuming I was going to do a firewall forward overhaul soon after. I would not rely on the "local mechanic's" opinion to conclude that the engine will not require an overhaul in the near future. (Unless he's willing to give you a warranty, and you think you can enforce it, of course). Good Luck! --ron |
On May 18, 5:22 pm, Greg Copeland wrote:
I spoke with a local mechanic today and his opinion is that it should give pause but the engine may be fine and was seemingly encouraged by the compression numbers. He recommends an oil analysis. His opinion is the biggest potential unseen danger stems from the cam and an oil analysis would address this concern one way or the other. Comments? Would you consider such a deal? The mechanic's advice seem sound? Oil analysis is a trend tool. Even the folks that sell the service will tell you that. A single oil analysis won't tell you much unless the engine is shedding a prodigious amount of metal (which you should be able to see by cutting open the oil filter). On Lycs that don't get much use, I'd pull a cylinder or two and inspect the cam directly. I know too many people that have bought underused engines that looked good at inspection, only to have the results of internal corrosion start showing up after they started flying it regularly. Personally, with the airplane market heavily favoring the buyer these days, I'd look elsewhere. This engine might be quite servicable, but the seller is asking you to stake your money that it is. There's no down side for him. John Galban=====N4BQ (PA28-180) |
In article . com,
Greg Copeland wrote: I've been shopping for a plane for a while. I'm hoping I found the one but the engine has given me pause. The engine is 17-years old. It has ~700 hours on it. The average per year is only 49hr/year. Two years during that 17, the plane did not fly and I'm guessing it was not pickled. The latest it sat was in 2000. During the last 6 years, the plane has mostly flown some 32hrs/year on average. The engine is a Ly IO-360-A1A. Compression on the engine is 74, 76, 74, 76. The owner refuses to negotiate on the basis of these concerns and leaves me nothing to mitigate some of the potential risk. I spoke with a local mechanic today and his opinion is that it should give pause but the engine may be fine and was seemingly encouraged by the compression numbers. He recommends an oil analysis. His opinion is the biggest potential unseen danger stems from the cam and an oil analysis would address this concern one way or the other. Comments? Would you consider such a deal? The mechanic's advice seem sound? Greg I would assume that the engine should be torn down and overhauled. Lycomings, especially, suffer from #1 and #2 cam erosion, due to condensation in the upper front of the crankcase. Oil analysis may or may not spot a problem here. Cylinders may be pitted due to condensation/atmospheric pumping. Some Hartzell propellers have a mandatory 5 year inspection cycle. If the plane has sat outside, airframe components may suffer from corrosion. Paint may need replacement. |
Orval Fairbairn wrote:
Lycomings, especially, suffer from #1 and #2 cam erosion, due to condensation in the upper front of the crankcase. Curious. Why would you get more condensation in the upper front part of the crankcase than anywhere else? |
Roy Smith wrote: Orval Fairbairn wrote: Lycomings, especially, suffer from #1 and #2 cam erosion, due to condensation in the upper front of the crankcase. Curious. Why would you get more condensation in the upper front part of the crankcase than anywhere else? That is the area where ventilation is least -- also, the highest point of the inside of the crankcase when the aircraft is at rest. |
And....
When preheating, the metal propeller is a HUGE heat radiator, keeps the front of the engine cooler than the rest, hence more condensation in that area.... Some get mittens for their props... ![]() Dave On Sun, 20 May 2007 14:00:11 GMT, Orval Fairbairn wrote: In article , Roy Smith wrote: Orval Fairbairn wrote: Lycomings, especially, suffer from #1 and #2 cam erosion, due to condensation in the upper front of the crankcase. Curious. Why would you get more condensation in the upper front part of the crankcase than anywhere else? That is the area where ventilation is least -- also, the highest point of the inside of the crankcase when the aircraft is at rest. |
Westland Wyvern Prototype - RR Eagle Engine - Rolls Royce Eagle 24cyl Liq Cooled Engine.jpg | Ramapo | Aviation Photos | 0 | April 17th 07 09:14 PM |
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg | [email protected] | Aviation Photos | 1 | April 11th 07 04:48 PM |
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg | [email protected] | Aviation Photos | 0 | April 9th 07 01:38 PM |
thrust line for engine and not mounting engine on this thrust line | tommyann | Home Built | 8 | December 15th 06 03:31 PM |
1710 allison v-12 engine WWII p 38 engine | Holger Stephan | Home Built | 9 | August 21st 03 08:53 AM |
