Prop sync and noise in twins
Old May 21st 07, 10:04 PM posted to rec.aviation.piloting
Mxsmanic
Default Prop sync and noise in twins
I note that the Baron (and presumably other twins) has a prop sync switch that
somehow synchronizes the prop speeds on both engines. From recordings I've
heard of the interior noise of the aircraft, it does sound as though props
that are just slightly out of sync can produce a very irritating intermittent
noise as they move in and out of phase. Is it very bothersome in real life?
Also, how does the prop sync work? Does it actually move pitch or throttle
levers or something?
Old May 21st 07, 10:45 PM posted to rec.aviation.piloting
Sylvain
I don't fly something fancy enough to have an automagic sync thingy; so I
go by ear. It is a bit like tuning a guitar really, but fiddling with the
throttle (you can't rely on either the throttle position nor the rpm
indicators, not precise enough).
--Sylvain
Old May 22nd 07, 12:59 AM posted to rec.aviation.piloting
RomeoMike
I was taught and always used the prop control for sync.
throttle
--Sylvain
Old May 22nd 07, 01:28 AM posted to rec.aviation.piloting
Sylvain
throttle
you are right, I was wrong. Ooops. what was I thinking? going
to hide myself under a rock for the next few hours...
--Sylvain
Old May 22nd 07, 09:52 AM posted to rec.aviation.piloting
Dylan Smith
Probably more like tuning a piano, since you're listening for the beat
frequency (or lack thereof).
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old May 21st 07, 11:20 PM posted to rec.aviation.piloting
John Theune
If you type in prop synch multi-engine planes into the google search
window the first hit you will see is this
The AVSIM Forums - Viewing topic #736 - Prop sync
Out of synch propellers will not be as obvious or as annoying in a
simulator as in a real plane. In most aircraft with prop synch, you
first manually ...
forums.avsim.net/dcboard.php?az=show_topic&forum=189&topic_id=736&m ode=full
- 56k - Cached - Similar pages
Go there , read it and you will know all you want to know.
Old May 22nd 07, 01:08 AM posted to rec.aviation.piloting
ManhattanMan
John Theune wrote:
switch that somehow synchronizes the prop speeds on both engines. From
recordings I've heard of the interior noise of the aircraft, it
does sound as though props that are just slightly out of sync can
produce a very irritating intermittent noise as they move in and out
of phase. Is it very bothersome in real life? Also, how does the
prop sync work? Does it actually move pitch or throttle levers or
something?
first manually ...
OMG - you want MX to actually *research* his trolling questions????
All by his little self????????
What fun is that??
Old May 22nd 07, 05:47 AM posted to rec.aviation.piloting
Mxsmanic
John Theune writes:
first manually ...
Thanks. I guess people in the AVSIM forums actually answer questions rather
than just point people to Google.
Old May 22nd 07, 12:13 PM posted to rec.aviation.piloting
John Theune
Mxsmanic wrote:
John Theune writes:
first manually ...
I had you blocked for a long time but took you off recently and see I
made a mistake. Your still as much of a ass as before. Try to do a
just a little bit of work yourself.
Old May 22nd 07, 03:35 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
John Theune writes:
first manually ...
&mode
=full - 56k - Cached - Similar pages
rather than just point people to Google.
Ooow 1Teh big flying circle jerk! you must be so happy there..
Bertie
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Piloting 26 January 13th 07 12:06 AM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Instrument Flight Rules 15 January 13th 07 12:06 AM
CompaqAero1530 sync question Stewart Kissel Soaring 0 February 21st 05 03:15 AM
Prop noise vs. engine noise Morgans Piloting 8 December 24th 03 03:24 AM
