What do your JPI readings show?
Jim |
Here's a WAG for conversation's sake. Is the EGT temp low on initial
start up / warm up, while operating at low rpms and or does it cool down faster than the others on shut down? Could the exhaust valve be sticking when cold, moving and wearing the guide in the boss, causing increased oil usage and both aluminum and steel in your samples yet showing good compressions after warming up? Like I said, completely a WAG. If you really suspect the cylinder, I would not fear pulling it for a thorough inspection. You'd get immediate knowledge of the condition of the piston and pin, the ability to examine the cylinder, the valves/ seats/guides, and check the rings, and even a peak at a few of the cam lobes. A wealth of knowledge available for relatively minor $. I've only had the need and the experience of pulling one cylinder, but under an A&P's guidance I removed it myself in less than 2 hours and we reinstalled it together in about 3 hours. Easier and cheaper to catch a problem before it becomes a disaster. |
On May 23, 3:59 pm, Jim Burns wrote:
Here's a WAG for conversation's sake. Is the EGT temp low on initial start up / warm up, while operating at low rpms and or does it cool down faster than the others on shut down? Could the exhaust valve be sticking when cold, moving and wearing the guide in the boss, causing increased oil usage and both aluminum and steel in your samples yet showing good compressions after warming up? Like I said, completely a WAG. If you really suspect the cylinder, I would not fear pulling it for a thorough inspection. You'd get immediate knowledge of the condition of the piston and pin, the ability to examine the cylinder, the valves/ seats/guides, and check the rings, and even a peak at a few of the cam lobes. A wealth of knowledge available for relatively minor $. I've only had the need and the experience of pulling one cylinder, but under an A&P's guidance I removed it myself in less than 2 hours and we reinstalled it together in about 3 hours. Easier and cheaper to catch a problem before it becomes a disaster. I've never had any symptoms of a sticky valve. In the 1000 hours I've had this engine there have been maybe two times the engine has stubbled slightly in flight (as a CFI I've seen this on many planes), and its never had any morning sickness. However, I'm not sure if the valve action relates to oil passing or not. Blackstone seems pretty sure this is a pin plug. At first they said it could be the dip stick but I would have been something on the stick by now. I guess if I pull the cylinder it will be obvious where the oil is coming from?? -robert |
| Thread Tools | |
| Display Modes | |
| Oil in cylinder, other cylinder issues | Robert M. Gary | Piloting | 7 | May 27th 07 06:26 AM |
| O2 cylinder | HL Falbaum | Soaring | 26 | February 9th 06 06:35 PM |
| bad cylinder | blanche cohen | Owning | 25 | February 2nd 06 06:15 PM |
| Bad cylinder | Denny | Owning | 17 | September 12th 05 07:04 PM |
| WTB: A65-8 Cylinder | Juan Jimenez | Aviation Marketplace | 0 | June 10th 05 05:38 AM |
