FAA advisory voids IFR certification for GPS's!!!
Old May 27th 07, 12:38 AM posted to rec.aviation.owning
Prime
Default FAA advisory voids IFR certification for GPS's!!!
I'm surprised nobody has posted about this.
Many GPS panel models are "no longer" IFR certified! Anybody else affected
by this, posted on AOPA web site? It's courtesy your FAA!
http://www.aopa.org/whatsnew/newsite...070524gps.html
We have a Garmin 300XL, which is one of the units supposedly no longer IFR
compliant. Needless to say all three of us in the partnership are besides
ourselves. We only put this in our plane a couple of years ago!
And how are you handling it? I assume that there's a good chance enough
complaints will cause this to be reversed.
I heard a birdie suggest to me that it was good so many pilots are unaware
of this, they might go ahead and keep flying IFR with those units! The
reasons are nitpicky for voiding the units, it is not a safety of flight
issue.
Prime
Old May 27th 07, 01:39 AM posted to rec.aviation.owning
Rich
issue.
Prime
Latest word is that the AOPA jumped the gun on this one. The new AC
addresses some RNAV (as in Flight Management Systems) specific Arrival
and Departure procedures, and NOT the enroute use of a GPS to identify
DME and NDB fixes, nor the use of approach approved GPS's for approaches.
Keep studying the news reports, but it seems to me that we who have
approach certified GPS's can continue to use them as we have been using
them.
Rich
Old May 27th 07, 02:49 AM posted to rec.aviation.owning
Ron Rosenfeld
issue.
Prime
them.
Rich
Look at AIM 1-2-3. Use of Area Navigation (RNAV) Equipment on Conventional
Procedures and Routes
b. Allowable RNAV Equipment. Subject to the requirements in this paragraph,
operators may use the following types of RNAV equipment as a substitute or
alternate means of navigation guidance:
1. An RNAV system with GPS or DME/DME/IRU inputs, installed in accordance
with appropriate airworthiness installation requirements, and compliant
with the equipment provisions of AC 90-100, U.S. Terminal and En Route Area
Navigation (RNAV) Operations. Standalone GPS systems, compliant with AC
90-100, are included in this set of equipment. A list of compliant systems
is available under "Policies & Guidance" at the following website:
http://www.faa.gov/about/office_org/...afs400/afs410/
2. An RNAV system with GPS or DME/DME/IRU inputs, lacking the capability to
automatically perform course-to-fix legs (also called path terminators),
installed in accordance with appropriate airworthiness installation
requirements, and otherwise compliant with the equipment provisions of AC
90-100. This subset of equipment includes some standalone GPS systems and
flight management systems that are authorized for instrument flight rules
(IFR) en route and terminal operations but not fully compliant with AC
90-100. However, these systems may not be used as a substitute or alternate
means of navigation guidance on segments of an instrument approach,
departure, or arrival procedure defined by a VOR course. This restriction
does not apply to routes, which may be selected by route name or
constructed by "stringing" together two or more waypoints from an onboard
navigation database. Many of these systems are identified on the
aforementioned website.
and the rest of it gets even more confusing. However, I believe it is the
reference to AC 90-100 compliance that is causing a lot of the angst.
--ron
Old May 27th 07, 03:22 AM posted to rec.aviation.owning
Peter R.
Then you don't read rec.aviation.piloting. It was first posted back on 5/25:
http://tinyurl.com/29zgky
Peter
Old May 27th 07, 07:46 PM posted to rec.aviation.owning
Jim Carter[_1_]
-----Original Message-----
From: Peter R. [mailto Posted At: Saturday, May 26, 2007 8:23 PM
Posted To: rec.aviation.owning
Conversation: FAA advisory voids IFR certification for GPS's!!!
Subject: FAA advisory voids IFR certification for GPS's!!!
5/25:
Peter
Pete,
I quit reading r.a.p. because of the tremendous amount of petty
bickering that goes on over there - especially surrounding MSXMANIAC and
his ilk. Even though I kill-filed his address and that of some other
similar trolls, the regular posters could not do the same and
continuously kept his threads alive (even though I couldn't see the
trolls' posts).
I finally had to give up, mostly because I don't have an
unlimited amount of time to read completely fruitless topics, and don't
want to spend the time downloading that junk. I'm not surprised to see
that others may be doing the same.
Old May 28th 07, 02:11 PM posted to rec.aviation.owning
Peter R.
his ilk.
Ah, sorry about that. I made the false assumption that anyone reading this
group also reads r.a.p.
I, too, was close to bailing due to the same reason when instead I started
using a newsreader that allows responses of killfiled posters to be ignored.
Now I don't see that poster or any responses and the group is actually quite
useful again.
Peter
Old May 28th 07, 04:32 PM posted to rec.aviation.owning
Jim Carter[_1_]
Default Off-topic - Was: FAA advisory voids IFR certification for GPS's!!!
Pete,
I'm using MAPILabs NNTP plugin for Outlook. It struggles with
kill files for news articles but works most of the time. I'd like to
know what reader you're using. I'm restricted to a Win environment on
this laptop because of some application requirements, and I don't
typically have my Linux platform with me while I travel.
started
ignored.
quite
useful again.
Peter
Old May 28th 07, 05:44 PM posted to rec.aviation.owning
Steve Foley[_2_]
I posted this back on Feb 1. Here it is again - works with Outlook Express
I found the following completely eliminates mxsmanic from usenet, along with
any responses to him. Using this, I don't need to killfile anyone else. Only
responses to polluted threads are gone.
Tools - Message Rules - News - - New:
Apply this rule after the message arrives
Where the From line contains 'mxsmanic'
Mark the message as ignored
View - Current View - Customize Current View:
View - Current View - Hide Read or Ignored Messages
Un-check 'Where the message has been read'
Change the name to 'Hide Ignored Messages'
View - Current View - Make Sure 'Hide Ignored Messages' is checked.
"Jim Carter" wrote in message
news:000b01c7a134$ef810590$4b01a8c0@omnibook6100.. .
Pete,
started
ignored.
quite
useful again.
Peter
Old May 28th 07, 08:05 PM posted to rec.aviation.owning
Peter R.
On 5/28/2007 10:32:09 AM, "Jim Carter" wrote:
I'd like to know what reader you're using.
I use a Windows-based reader called Newsman Pro, which is actually a payware
product found he www.newsmanpro.com
This newsreader may be more feature-rich than you prefer, though. Instead,
you would be served well by using Outlook Express and Steve Foley's
directions (posted previously here - thanks, Steve) of how to configure it to
block posters and their replies.
Good luck and hope to see you back in r.a.p. We need some more good signal
makers there.
Peter
Old May 28th 07, 09:56 PM posted to rec.aviation.owning
Jim Carter[_1_]
I was using OE for my school work at Univ of Phoenix, but it seems to
maintain a separate address book. I've yet to figure out how to maintain
a single address book for Outlook and Outlook Express. If that could be
done then I'd go back to OE for all my news services. I prefer the
single AB because I use a Blackberry and sync Outlook between my home
and work laptops.
From: Peter R. [mailto Posted At: Monday, May 28, 2007 1:06 PM
Subject: Off-topic - Was: FAA advisory voids IFR certification
for
GPS's!!!
payware
Instead,
configure it
to
signal
makers there.
Peter
Stupid Attorney taling about GPS's Gerald Sylvester Piloting 90 February 24th 04 03:30 AM
Updates to Headsets, GPS's and Radios forsale George Piloting 0 January 13th 04 02:07 AM
HeadSets, Handheld Radios and GPS's forsale all NEW. George Piloting 0 January 9th 04 04:01 PM
HeadSets, Handheld Radios and GPS's forsale all NEW. George Aviation Marketplace 0 January 9th 04 04:01 PM
S-H Spars: Anyone check for voids laterally? Mark Grubb Soaring 1 September 20th 03 05:27 AM
