My next proposed flight.
Old May 28th 07, 04:29 AM posted to rec.aviation.piloting
NW_Pilot
Default My next proposed flight.
Hey all, Here is my next proposed flight it's going to be a blast... Will
take photos if the ocean.... & Islands hahaha!!!! All insured ferry permits
etc. waiting on bank wire will then set launch date should be about the 31st
depending on winds and weather!!!
The Route!!! Lower 48, DCT Hawaii, DCT Micronesia (Majuro), DCT Guam, DCT
Philippines....
(Replace the ** with tt)
h**p://www.aircraftdelivery.net/flitestar/rplb.jpg
Will upload photos of ferry tanking job etc :-)
Old May 29th 07, 04:53 AM posted to rec.aviation.piloting
J. Severyn
"NW_Pilot" wrote in message
permits etc. waiting on bank wire will then set launch date should be
about the 31st depending on winds and weather!!!
Philippines....
Sounds interesting!!!! What kind of aircraft??
J. Severyn
KLVK
Old May 29th 07, 02:34 PM posted to rec.aviation.piloting
Jim Burns[_2_]
Looks like an Aero Commander. I'd be very interested to see how they rig
the fuel system. I recently saw Hartwig's "regular" fuel bladder list for
the Aero Commander... 22, yes TWENTY TWO bladders.
Old May 29th 07, 09:38 PM posted to rec.aviation.piloting
NW_Pilot
"Jim Burns" wrote in message
It's hard to get the FAA to approve bladders for auxiliary tanking these
will be welded aluminum boxes like most every other approved tank.
Old May 29th 07, 09:58 PM posted to rec.aviation.piloting
NW_Pilot
"J. Severyn" wrote in message
news
Will take photos if the ocean.... & Islands hahaha!!!! All insured ferry
Philippines....
J. Severyn
KLVK
Aero Commander 500
Old May 29th 07, 10:36 PM posted to rec.aviation.piloting
Jim Burns[_2_]
Interesting, although I was referring to the standard configuration, not a
ferry adaptation, and it seems the models I was referring to are the 685 and
690. http://www.eaglefuelcells.com/assets...s/7aerocom.pdf What a
plumbing nightmare that fuel system must be.
Old May 29th 07, 10:46 PM posted to rec.aviation.piloting
NW_Pilot
Lets try Again!!!!
Aero Commander 500
Tanked For a Total of 376 Gallons Useable "156 Gallons Stock 220 Aux."
15% Over Gross Special Flight Permit
Cruising Altutide will take place at FL100 or FL120 @ 55-60% Power.
Power Plant:
Lycoming O-540-A2B
Horsepower Rating 250hp @ 2575 RPM
Fuel, octane - capacity (Gal) 91/96 - 156
Fuel Consumption GPH 11.9
Propeller 80" 2-blade
Weight (lb), empty - gross 3850 - 6000
Dimensions: Wing span (Inches) - area (Sq ft)588.56 - 255.00
Fuselage length - height (Inches)421.25 - 174.00
Volume, cabin - baggage area (Cubic feet)177 - 32
Seats 5 - 7
Performance:
Takeoff over 50' obstacle1,400
Landing over 50' obstacle1,350
Service ceiling (feet) 22,500
Single-engine ceiling 8,000
Maximum range (miles) 1,100
Cruising speed (70% @10,000 ft) 199
Takeoff - landing speed 87 - 82
Best rate-of-climb110
New proposed MOA new Ely NV Ron Gleason Soaring 7 August 15th 06 12:35 PM
Another letter against the proposed bill Andrew Sarangan Piloting 0 September 15th 04 05:34 AM
US Team Selection - Proposed Changes John Seaborn Soaring 0 November 27th 03 10:25 PM
Proposed new flightseeing rule C J Campbell Home Built 56 November 10th 03 06:40 PM
