Question ??
Old June 20th 07, 06:11 AM posted to rec.aviation.piloting
Thomas Buyea
Default Question ??
Do people flying small aircraft like a veterinarians for farm animals
that covers large areas in their work, Land on roads out in the country
Is it legal and do they normally do it legal or not.
When they can see there are no cars for miles.
Old June 20th 07, 06:38 AM posted to rec.aviation.piloting
BT
Default Question ??
State your country or location... in most parts of the USofA, it is not
legal to use a public highway for a runway. The local "State" Dept of
Transportation" may deem it an emergency landing and could impound the
aircraft for the safety investigation, bringing in their state dept of
aviation and could restrict your departure from the roadway.
Some local constabularies, after allowing an aircraft to take on fuel after
a landing forced by lack of fuel or a "precautionary landing for a rough
engine", have blocked the roadway to allow a departure, only to have the
hapless pilot strike a roadside obstruction with the wing and have a worse
crash than the first "safe" landing.
JMHO
BT
"Thomas Buyea" wrote in message
Old June 20th 07, 04:41 PM posted to rec.aviation.piloting
C J Campbell[_1_]
Default Question ??
It depends on local laws. Aircraft are generally not legal to use as
automobiles: no tail lights, horn, etc., plus they are too wide to fit
in a single lane. I know one aircraft owner who had been landing near
his home way out in the desert for years. Nobody ever complained (heck,
hardly anyone even knew about it) until a local sheriff finally gave
him a ticket for no tail lights. Other issues, of course, would be
speed limits on the local roads, etc. But basically, the FAA does not
care where you land your plane as long as you do it safely and within
the limitations of both you and the aircraft.
There are places around the country where sections of roads have been
designated as runways. Some roads have actually been built over the top
of old runways and planes continue to use them. Also, whether it is
legal or not, in some local areas the authorities are likely to ignore
it. After all, if you prevent a veterinarian from landing his plane on
a road in order to treat some rancher's prize bull, both the rancher
and the vet are less likely to be available if you ever need their
help. What goes around comes around.
Of course, you can do anything you like on a private road on your own ranch.
Waddling Eagle
World Famous Flight Instructor
Old June 20th 07, 08:52 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
Default Question ??
As stated above, the FAA doesn't care. State and local laws will apply.
I know that Alaska allows aircraft to land on public roads, and I've done it
a few times there.
I know a veterinarian that used to fly out to remote ranches in NM and TX.
Most ranches had a strip carved out somewhere on the property. If there was
none, he would use one of the private roads on the ranch property.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200706/1
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 07:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 02:11 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
