Fuel tank foam
Old June 24th 07, 10:03 PM posted to rec.aviation.homebuilt
Stuart & Kathryn Fields
Default Fuel tank foam
Is there anyone out there using fuel tanks filled with open cell foam? I've
heard that explosions are tamed as well as fuel slosh. I've also heard that
the foam must be replaced periodically. How often is the replacement
necessary? I'm using 100LL Av gas.
Stuart & Kathryn Fields, Publishers
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
(760) 408-9747 publication cell
(760) 608-1299 technical cell
www.experimentalhelo.com
www.vkss.com
Old June 25th 07, 05:07 AM posted to rec.aviation.homebuilt
Orval Fairbairn
Most of the foam is polyurethane foam, which decomposes after exposure
to water vapor. It is not an instantaneous process, occurring over
several years, but the decomposition product is a black powder, which
can clog fuel filters, injectors, etc.
It is good for race cars, which have a limited useful life, but may
impose problems in aircraft, which operate for years.
Old June 25th 07, 01:35 PM posted to rec.aviation.homebuilt
Ron Natalie
Fuel cells (bladders with foam) are pretty common in the auto racing
industry. They real purpose of it is to avoid the fuel from spraying
out if the tank is ruptured. Other than that I'm not sure what
"explosion" resistance you're going to get. I suppose it might
mitigate some sloshing. I'd make sure that I was getting the
max flow rate for takeoff if I were to use one in an aircraft.
The big drawback is that they drastically decrease the fuel
carried per unit volume.
Old June 25th 07, 07:39 PM posted to rec.aviation.homebuilt
JP[_1_]
"Stuart & Kathryn Fields" wrote in
I've heard that explosions are tamed as well as fuel slosh. I've also
heard that the foam must be replaced periodically. How often is the
replacement necessary? I'm using 100LL Av gas.
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
www.vkss.com
Aero Tec Laboratories Inc
http://www.atlinc.com/US/racing.html
http://www.atlinc.com/US/catalogs.html
Some ATL Fuel Cells catalogs.
http://www.atlinc.com/US/faqs_racing.html
Here's some answers concerning the foam replacement etc.
JP
Old June 26th 07, 01:18 AM posted to rec.aviation.homebuilt
Morgans[_2_]
That should not be a problem, considering the run NASCAR engines with it,
putting out 750+ HP, at constant wide open throttle, for lap after lap, at
some tracks. Our biggest engines putting out around 300 HP would not drawn
nearly as much.
It seems to me that if you were willing to overlook the weight, the extra
volume to carry the same amount of fuel, and the extra $$$, the fact that
they can wear out and plug up your fuel system is a show stopper.
Old June 26th 07, 02:58 AM posted to rec.aviation.homebuilt
JP: Thanks for the links. I've learned enough to avoid fuel tank foams.
When the engine suddenly gets quiet in my helicopter, my suds level gets
pretty high.
Thanks again.
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
www.vkss.com
"JP" wrote in message
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
www.vkss.com
JP
Old June 26th 07, 03:49 AM posted to rec.aviation.homebuilt
Richard: I agree the deterioration of the foam is a show stopper for me.
thanks
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
www.vkss.com
"Richard Riley" wrote in message
On Mon, 25 Jun 2007 07:35:36 -0400, Ron Natalie
I've
that
I looked at the foam a few years ago. Google Reticulated Polyurethane
Foam Fuel Explosion and you'll find a few technical papers.
You take about a 3% hit on fuel volume, and you increase empty weight
by about the same. It does break down over time - the racing bladders
are only rated for 5 years. The breakdown occurs MUCH more rapidly in
the presence of an oxygenating fuel like ethanol.
I decided against it, I can't open up my tanks every few years to
replace it.
Old June 26th 07, 06:56 PM posted to rec.aviation.homebuilt
Maxwell
"Stuart & Kathryn Fields" wrote in message
Perhaps a few metal baffels would be a better choice.
Old June 26th 07, 08:06 PM posted to rec.aviation.homebuilt
I have a couple of baffles already, but having 28 gal 100LL just behind my
head makes my nerves twitch just a bit. Having the foam is supposed to make
explosive conflagration less likely in case of a prang.
Thanks
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
www.vkss.com
"Maxwell" wrote in message
Old June 26th 07, 10:04 PM posted to rec.aviation.homebuilt
Maxwell
I wonder how the safety of the foam would compare to a bladder? It would
certainly complicate the slosh issue, but might provide greater safety in
case of an incident.
make explosive conflagration less likely in case of a prang.
Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg [email protected] Aviation Photos 0 April 12th 07 02:33 AM
Fuel tank balance Mxsmanic Piloting 101 October 3rd 06 08:56 AM
fuel tank plumbing pwm Home Built 18 January 27th 05 05:54 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
blue foam, pink foam, yellow foam? Corrie Home Built 26 September 1st 03 06:01 PM
