Speed wing extensions
Old July 10th 07, 04:06 PM posted to rec.aviation.homebuilt
Default Speed wing extensions
I have just recently extended my C model speed wings. I removed the
Original wing bow tips and added 48 inches of lift to each wing with
flat tips. The situation now is I have a good bit of wash out. Enough
to where when the tail of the plane is lifted to where the she would
be in level flight, the wing tip actually has a little negative angle
of attack. The plane flies fine but a little more tail down than I
like. My next thought is to remove the extra 12 inches of wing to
reduce the negative angle a bit. Anybody out there got any
constructive experience or ideas, I be interrested to get your
opinion.
Thanks Walt
USB connectors/extensions for 396 XM antenna [email protected] Owning 9 May 14th 07 09:11 AM
DG-1000 undercarriage collapses and inadvertent extensions ? Bernie[_2_] Soaring 24 May 1st 07 03:14 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 10:26 PM
Why are delta wing designs reputed to lose speed during turns? Air Force Jayhawk Military Aviation 2 September 25th 03 01:50 PM
Wing Extensions Jay Home Built 22 July 27th 03 01:23 PM
