installing mylar
Old July 29th 07, 06:41 PM posted to rec.aviation.soaring
mmartin via AviationKB.com
Default installing mylar
I've read all the posts, several times, regarding mylar seal replacemate. My
LS3-A needs the seals replaced and am considering doing the job myself. Is
this something a reasonabley compitent person can do on his own, or should
this be left to a pro? Your input would be appreciated.
Regards
mmartin
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...aring/200707/1
Old July 29th 07, 07:57 PM posted to rec.aviation.soaring
John Sinclair
Most owners can do a credible job of installing mylar
if they follow the rules:
1. Remove all gunk with acetone and elbow grease.
2. Sand the new mylar (just the 10mm that will be sttached)
and the corresponding area on the wing with 220 dry.
3. Clean wing with acetone and apply the double-back-sticky,
making sure to follow the edge and keep it straight!
4. Clean the mylar with acetone and follow the edge
of the sticky very closely (don't make any abrupt corrections
or you will form a kink) Keep tention on the mylar
as you remove about 24' on protectice covering from
the sticky, as you work along. I work from left to
right, always!
5. Force Mylar down by running over it with a small
roller, I use a small roller bearing on a stick.
6. Clean with acetone and apply the transition tape
(I use 20mm)
NOTE, be sure to use mlar that is wide enough to cover
all hinge recesses, but don't go any wider than necessary
or stick forces will increase. Hinge recesses can be
covered separately with small pieces of plastic (mylar)
held down with sticky, then covered with wide tape.
Ideally, movement of the control should not lift the
mylar.
Have fun,
JJ
the job myself. Is
Regards
mmartin
Old July 31st 07, 03:55 AM posted to rec.aviation.soaring
ContestID67
I did it myself and it was quite easy. I assume that these are
external seal tape, not internal seals.
The previous post mentioned sanding with 220. I didn't and wouldn't.
In my book
gelcoat and sandpaper should stay far, far, apart. The seals have
stuck for
3 years now with zero problems.
Having a friend help get things on straight is useful.
- John
Old July 31st 07, 07:06 AM posted to rec.aviation.soaring
bumper
"ContestID67" wrote in message
In my book
stuck for
- John
John,
Your choice not to sand. However, if you check with some of the adhesive
mfgs(3M has good info on their site), you'll find that sanding is
recommended for optimal results with acrylic adhesive as are used to stick
down Mylar. Light sanding of the surfaces to be bonded is the way to go as
it provides the adhesive with more bonding surface and mechanical "bite".
As JJ noted, it's also important to have the surfaces squeaky clean, use
pressure (roller), and only apply tape to warm surfaces for best results.
Also position controls to keep pressure off the Mylars for a few hours as
acrylic gains strength over the first 24 or so.
bumper
Old July 31st 07, 11:07 AM posted to rec.aviation.soaring
Ray Lovinggood
I'm following this thread with interest. I've had
problems with mylar not sticking to the double sided
tape. The tape sticks quite well to the gel coat,
but the mylar doesn't want to stay stuck to the double
sided tape.
I've been accused of having an engine on my glider
as I pass over the airfield. But it's just that damned
loose mylar buzzing.
Of course, the hardest part of dealing with mylar is
getting the old stuff completely removed. The next
hardest is figuring out how to insure the mylar stays
stuck to the double sided tape.
Any ideas?
Ray Lovinggood
Carrboro, North Carolina
LS1-d(t) :-)
At 06:12 31 July 2007, Bumper wrote:
'ContestID67' wrote in message
roups.com...
these are
and wouldn't.
In my book
The seals have
stuck for
- John
Old July 31st 07, 01:52 PM posted to rec.aviation.soaring
John Sinclair
Ya got to sand it Ray, believe me that shiny surface
won't hold the bond. I have seen a whole lot of mylar
that didn't stick over the years, but to my knowledge,
none has come off that I installed using light sanding
with 220 dry. I'm only talking about the 10mm strip
under the mylar. There's nothing new here, we must
sand before painting, we must sand before applying
resin. it gives the surface a 'tooth'. Every now and
then I see a fiberglass patch that someone has scabbed
on without sanding the surface, I just get a fingernail
under one side and off it comes easier than removing
wing tape.
JJ
Any ideas?
Ray Lovinggood
LS1-d(t) :-)
groups.com...
these are
and wouldn't.
In my book
The seals have
stuck for
- John
Old August 1st 07, 04:46 PM posted to rec.aviation.soaring
JJ
Thanks for the advice. I will be taking on this project this week. Also,
Awhile back there was a thread regarding the LS3 and landing gear. You had
mentioned about testing the gear gas spring by pushing on the overcenter lock.
I could have retracted the gear and there was no snap back to the down
position. Your advice saved me from the gear eventualy retracting on roll
out.
Thanks
right, always!
(I use 20mm)
mylar.
Have fun,
JJ
[quoted text clipped - 7 lines]
mmartin
http://www.aviationkb.com/Uwe/Forums...aring/200708/1
Old August 1st 07, 05:47 PM posted to rec.aviation.soaring
gfoster07k
On Aug 1, 8:46 am, "mmartin via AviationKB.com" u36204@uwe wrote:
JJ
out.
Thanks
right, always!
(I use 20mm)
mylar.
Have fun,
JJ
mmartin
Message posted via AviationKB.comhttp://www.aviationkb.com/Uwe/Forums.aspx/soaring/200708/1- Hide quoted text -
- Show quoted text -
I have done this a couple of times and the seals were just fine for
about 5 years at a time. A couple of comments. The requirement to
get the old stuff off is critical. It means EVERY bit of the old
stuff so that the wing is pure white. The other comment relates to
the type of double sided tape. I used Tesa Polyester Tape used to
attach trim like chrome molding on cars. I got it at a body shop
supply store. My seals had been originally recessed into the gel coat
on top of the wings so the leading edge of the seal is flush and I
used a tape width that was as wide as the recess, (about 5/8 inch if I
remember right) to get maximum adhesion surface. The seals were
slightly cambered so the use of a small (linoleum in my case) roller
is also important to closely follow the removal of the tape second
side protective film. Otherwise the seal sticks at the inner and
outer edges due to the camber. Yes, I did 220 grit both the wing and
seal.
For what it is worth.
Greg .
Old August 1st 07, 10:41 PM posted to rec.aviation.soaring
John Sinclair
Thanks Mike,
About the only thing I could add is to replace the
transition tape every couple of years. It doesn't hold
up too well and can be a bear to get off if allowed
to deteriorate too much. I buff out my bird every
other year and then replace the transition tape before
waxing everything.
Cheers,
JJ
While I'm pontificating, my bird has never gone together
well, the right wing always hangs up going on or off.
I marked both lift fittings with magic marker and forced
it together, then removed the wing to see just where
it was hanging up......forward side of forward lift
fitting and aft side of aft lift fitting! Looks like
my fuselage is a tad to small or my right wing is a
tad too big. What to do? I tried scrubbing the indicated
areas with emery cloth by scrubbing them like shinning
a shoe. Did this for a good hour and things got better,
but she still didn't go together easily. Next I wound
a 12' X 2' hunk of 80 grit sandpaper around a 1/8'
drill bit and held it in place with masking tape at
the bottom. The next time I went soaring I was armed
with my sandpaper roll and a battery operater drill.
Yep, I stuck it in the forward lift fitting hole and
gave it a good 20 second blast while holding forward
pressure and slowely moving it in and out, making sure
to hold it at 90 degrees to the root rib (did the same
with the aft hole while holding aft pressure) WHALLA,
my ship now goes together without any cursing!
Cheers,
JJ
At 15:48 01 August 2007, Mmartin Via Aviationkb.Com
JJ
this week. Also,
back to the down
retracting on roll
out.
Thanks
right, always!
(I use 20mm)
mylar.
Have fun,
JJ
mmartin
Old August 2nd 07, 02:31 AM posted to rec.aviation.soaring
Ray Lovinggood
Thank You, JJ. I'll make this the next project to
tackle. Hopefully, this coming weekend.
Ray Lovinggood
Carrboro, North Carolina, USA
LS1-d(t) (when the mylar is loose and buzzing in the
breeze!)
wing tape.
JJ
Any ideas?
Ray Lovinggood
LS1-d(t) :-)
egroups.com...
these are
and wouldn't.
In my book
The seals have
stuck for
- John
Mylar tape [email protected] Soaring 1 October 31st 06 10:37 AM
Mylar seals for PIK20D culverflyer Soaring 5 May 19th 04 06:25 PM
ZZ Mylar seals Mike Soaring 3 March 29th 04 03:45 PM
mylar seals D.A.L Soaring 1 February 23rd 04 07:15 PM
Mylar (again) JJ Sinclair Soaring 0 December 11th 03 10:40 PM
