Alloys for certified parts?
Old July 31st 07, 04:28 AM posted to rec.aviation.homebuilt
Default Alloys for certified parts?
I have run across someone who insists that
6061 T6 is not "aircraft grade aluminum".
He claims that there are no certified parts made
from 6061. I find that hard to believe. Aren't there
certified aircraft with welded aluminum frames?
FF
Old July 31st 07, 02:40 PM posted to rec.aviation.homebuilt
That is a pretty broad statement.
Parts are made from any materials that the manufacturer
desires/specifies. Wood, aluminum, brass, glass and anything in between.
That includes 6061 of all tempers.
That is kinda what I thought. I'd like to find some specific examples
of certified aircraft parts made from 6061. I took a gander at
Aircraft
Spruce's online catalog, but the search function isn't set up for
that.
I'm thinking that certified metal props will probably be 6061 too.
FF
Old August 1st 07, 03:06 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Tue, 31 Jul 2007 22:42:40 -0700, John Kimmel
Aircraft
that.
FF
Main rotor blade and tail rotor blade spars and skins for Sikorsky S-61
and CH-53 are 6061-T6
the Fokker friendship was built from 6o61 as are the chris heintz
designs.
metal props are usually 2025.
Stealth Pilot
Old August 2nd 07, 02:55 AM posted to rec.aviation.homebuilt
On Aug 1, 8:06 am, Stealth Pilot
Aircraft
that.
FF
designs.
Stealth Pilot- Hide quoted text -
- Show quoted text -
The Cessnas I work on every day have a lot of extruded angle
in them, and I bet much of it is 6061T6. Perhaps the spar caps are
2024T3 extrusions.
Dan
Old July 31st 07, 04:26 PM posted to rec.aviation.homebuilt
On Jul 31, 2:30 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
FF
The LSA certified Zeniths are 6061-T6.
Aha!.
I see that Aircraft Manufacturing & Development Co. (AMD)
sells FAA certified SLSA Zodiacs.
FF
Old August 1st 07, 11:12 AM posted to rec.aviation.homebuilt
Vaughn Simon
ps.com...
While I believe you are on the winning side in your argument about aircraft
materials, the Zodiac may not be the best example to prove your point. As an
LSA, tt is certified to an industry standard, not an FAA standard. I recently
checked out in one and it even has a "warning" in the cockpit to that effect.
Vaughn
Non-certified parts for a certified plane? Dico Owning 10 August 22nd 06 03:11 AM
"certified' parts Jimmy B. Owning 51 March 18th 05 06:04 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Home Built 0 January 10th 04 02:20 AM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Aviation Marketplace 0 January 10th 04 02:20 AM
