density altitude calculator and wind calculator on web site and asGoogle gadget
Old August 4th 07, 10:19 PM posted to rec.aviation.piloting
Howie
Default density altitude calculator and wind calculator on web site and asGoogle gadget
July issue of AOPA pilot considered density altitude a major topic. I
have looked a bit around on the net and found formulas to compute exact
density altitude from indicated altitude and weather data.
(http://wahiduddin.net/calc/density_altitude.htm) Well, I implemented
these formulas into a Google gadget. You can find it at
http://airspace-v.com/ggadgets
You can add it to Google, use it on http://www.airspace-v.com, or put it
on your own web site. Of course, this also holds for other gadgets
listed on this page. There is at least one more gadget interesting for
flight preparation: The wind calculator to compute heading and flight
time from TAS, course, wind speed and wind direction.
Different units of measurement are supported. You may even mix them.
virtuPIC
P.S.: You have sauna experience? At altitude ? In ski holidays?
Calculate the corresponding density altitude! I know why I am yawning in
there. ;-)
Airspace V - international hangar flying!
Old August 5th 07, 03:39 AM posted to rec.aviation.piloting
Montblack
Default density altitude calculator and wind calculator on web site and as Google gadget
("Howie" wrote)
there. ;-)
http://www.airspace-v.com/ggadgets/densityAltitude.htm
Fun! ...I thought so anyway.
900 ft .....Elevation
110 F ....Temp
29.92 ....Barometer guess
90% ......Humidity
5,282 ft .....@ the Y.M.C.A.
(What?? That's where the steam room is. g)
Paul-Mont
Old August 5th 07, 11:32 PM posted to rec.aviation.piloting
d&tm[_2_]
"Montblack" wrote in message
snip
110 F ....Temp
90% ......Humidity
Where does elevation come into it? temp, pressure and humidity defines the
density of the air ( 1.083kg/m3 in this case) , which is then compared to
the density of the standard atmosphere, which in my calcs gives 4140 ft as
the density altitude.
terry
Old August 6th 07, 12:52 AM posted to rec.aviation.piloting
Newps
Default density altitude calculator and wind calculator on web site andas Google gadget
900 is where you start.
snip
110 F ....Temp
90% ......Humidity
terry
density altitude calculator and wind calculator on web site and asGoogle gadget virtuPIC[_2_] General Aviation 0 August 4th 07 06:55 PM
VFR xcountry calculator/log (NEW!!!) Cecilia Lang Piloting 0 December 26th 05 11:45 AM
E6B calculator for IPAQ? Paul kgyy Piloting 2 May 14th 05 12:05 PM
Calculator Phoebus_810 Soaring 0 January 8th 05 05:36 PM
JSW Glide Calculator snaproll59 Soaring 5 November 7th 04 05:01 PM
