I know I've read of the 3-spike plates used for tiedowns @ Oshkosh. Does someone sell same? A friend is putting up a tent/outbuilding, and screwing those augers into his solid clay is No Phun [tm]. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
On Mon, 13 Aug 2007 02:33:06 +0000 (UTC), David Lesher
wrote: I know I've read of the 3-spike plates used for tiedowns @ Oshkosh. Does someone sell same? A friend is putting up a tent/outbuilding, and screwing those augers into his solid clay is No Phun [tm]. -- Nutin holds like those augers. Get a longer lever and take a beer break halfway through if you need to. For the cost of one of those fancy 3 spike thingys he can buy all the augers he needs at the local farm store. |
Drew Dalgleish wrote: On Mon, 13 Aug 2007 02:33:06 +0000 (UTC), David Lesher wrote: I know I've read of the 3-spike plates used for tiedowns @ Oshkosh. Does someone sell same? A friend is putting up a tent/outbuilding, and screwing those augers into his solid clay is No Phun [tm]. -- Nutin holds like those augers. Get a longer lever and take a beer break halfway through if you need to. For the cost of one of those fancy 3 spike thingys he can buy all the augers he needs at the local farm store. The augers are worthless in hard ground. Here in the west they wouldn't go an inch into the ground. The Claw is the best I've found. |
go an inch into the ground. The Claw is the best I've found. Agreed. But their price is absurd. I built my own version for about $20, including the hammer and carrying sack. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck writes:
The augers are worthless in hard ground. Here in the west they wouldn't go an inch into the ground. The Claw is the best I've found. Agreed. But their price is absurd. I built my own version for about $20, including the hammer and carrying sack. Thanks to all. We've considered the auger approach; but in this clay, we must both twist with a 3' piece of rebar AND bang on the top to encourage it into the good earth. This is called "work"... This might be doable, but we already assembled the 12'*6' frame for the structure; and that means: turn 180, slide rebar to clear leg, bang, turn 180.. This is a PITA. We've considered renting the smallest gas-driven post hole digger; and adapting its output shaft to drive the augers, but..... [I'd suggested borrowing the well-drilling rig currently in his back yard while the crew was home, but he decided they might object, and it would not fit under the trees easily...] The Claw & others look to be about 80% suited to what we want. Their existence, as well as the EAA page [which I can't find but he could earlier...] helped convince him that angled straight spikes could do the job. [He has long experience flying around in various aircraft, from Helio Super Couriers & Hueys to Herc's; often with many bullet holes. Some of these he exited from when it was on the ground, others at high altitudes w/ slow rides down...] We now plan to put down pressure-treated 2*4's 12' long; drilled at ~30 degree angles to the vertical. We'll use ~30' lengths of rebar with a welded nut & a fender washer or two, and hammer them into the clay. Then we'll lag-screw the structure legs to the 2x4's. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
"David Lesher" wrote in message ... We now plan to put down pressure-treated 2*4's 12' long; drilled at ~30 degree angles to the vertical. We'll use ~30' lengths of rebar with a welded nut & a fender washer or two, and hammer them into the clay. Then we'll lag-screw the structure legs to the 2x4's. 30'...or 30" |
Skychick doesn't like them:
http://www.skychickadventures.com/Di...cles.asp?ID=12 "Curator" N185KG "Jay Honeck" wrote in message oups.com... The augers are worthless in hard ground. Here in the west they wouldn't go an inch into the ground. The Claw is the best I've found. Agreed. But their price is absurd. I built my own version for about $20, including the hammer and carrying sack. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Drew Dalgleish" wrote in message ... On Mon, 13 Aug 2007 02:33:06 +0000 (UTC), David Lesher wrote: Nutin holds like those augers. Get a longer lever and take a beer break halfway through if you need to. For the cost of one of those fancy 3 spike thingys he can buy all the augers he needs at the local farm store. For permanent tiedowns, I would try to go with augers. The best way to screw them down is with a long lever and a friend with a sledgehammer. Screw the thing down until it gets tight (that might be very quick) and have the friend tap the auger with the sledge as you turn it. I usually expect a quarter turn from each tap. I usually dig a posthole about 1/2 depth, insert the auger, and replace the dirt. That gives you a good start while still allowing the auger to dig down into undisturbed dirt. You can also posthole down full depth, and carefully compact the dirt on top of the auger, but you will not have full hold-down strength available until the dirt settles on its own, a matter of weeks or months. Vaughn |
break halfway through if you need to. For the cost of one of those fancy 3 spike thingys he can buy all the augers he needs at the local farm store. Power Auger Drivers (both electric and gasoline powered) are available. No doubt some equipment rental shops have them. David Johnson |
| Thread Tools | |
| Display Modes | |
| Govt Plates | Mike Granby | Instrument Flight Rules | 103 | November 27th 06 08:12 AM |
| Backup plates on PDA | Stan Prevost | Instrument Flight Rules | 29 | December 10th 04 03:42 AM |
| Plates for PDA? | Kelly Bakst | Instrument Flight Rules | 29 | September 3rd 04 06:21 AM |
| data plates | Del Rawlins | Home Built | 2 | August 21st 04 11:34 PM |
