Briegleb
Old August 18th 07, 02:23 AM posted to rec.aviation.soaring
Robert Gaines
Default Briegleb
Are there any BG-7's in America?
reply to
Old August 18th 07, 03:11 AM posted to rec.aviation.soaring
Vaughn Simon
Default Briegleb
"Robert Gaines" wrote in message
According to the Soaring 1997 sailplane directory, there was then 1 in the
USA. 3 were factory built and 20 kits were sold.
Vaughn
Old August 18th 07, 04:04 AM posted to rec.aviation.soaring
Default Briegleb
According to
http://www.aircraftone.com/aircraft/..._7_79001kz.asp there
are two registered in the US; however, there is a note that the one in
Placerville, CA may not be airworthy.
HP-14 "6F"
http://www.soaridaho.com/
"Vaughn Simon" wrote in message
message ...
the USA. 3 were factory built and 20 kits were sold.
Vaughn
Old August 19th 07, 04:10 PM posted to rec.aviation.soaring
Default Briegleb
On Aug 17, 10:04?pm, "Wayne Paul" wrote:
According tohttp://www.aircraftone.com/aircraft/models/briegleb_bg_7_79001kz.aspthere
HP-14 "6F"http://www.soaridaho.com/
Vaughn- Hide quoted text -
- Show quoted text -
As Wayne mentioned,there are two currently listed on the FAA books.
The status of N4565K in California is listed as "revoked", while
N4032A in Wisconsin is listed as "valid". You can, of course find the
location on the FAA registry of aircraft type and N-numbers.
Gary Adams
Old August 19th 07, 04:33 PM posted to rec.aviation.soaring
Vaughn Simon
Default Briegleb
"Wayne Paul" wrote in message
According to
http://www.aircraftone.com/aircraft/..._7_79001kz.asp there are
This is a case where the registration files can be particularly difficult to
use, since most BG-7s were apparently homebuilts. For example: a homebuilt
Briegleb BG-7 built by John Doe might be registered as a "Doe BG7"-
Also, the sailplane directory mentions that modifications were common, including
spoilers, cockpit mods, fuze lengthening, and vertical fin mods. The bottom
line is that there may be several BG-7s in the USA hiding under assumed names
and obscured with clever disguises.
Vaughn
WTB: Plans for Briegleb BG-12 BD noel56z Soaring 1 September 9th 05 01:35 AM
Briegleb 12B - Opinions? Eggs Soaring 22 December 31st 03 08:20 PM
