flightcom 403mc auxillary audio question
Old August 20th 07, 01:37 AM posted to rec.aviation.owning
Mike Noel
Default flightcom 403mc auxillary audio question
I've just upgraded to a garmin 496 from a 296 and want to hook up the audio
output to the intercom. I haven't had a chance to look at the back of the
intercom. Can anyone tell me what kind of auxiliary connection the 403mc
uses? I would like to make up a patch cable before I visit the hangar next
weekend. Thanks.
Best Regards,
http://photoshow.comcast.net/mikenoel
It is not work that kills men; it is worry. Worry is rust upon the blade.
Old August 20th 07, 05:28 PM posted to rec.aviation.owning
Thomas Borchert
Mike,
uses?
The manual. I think it's on their website. Common procedure is to route
from the back to a mini-plug somewhere in the panel as used on MP3
players and the like.
Thomas Borchert (EDDH)
Old September 1st 07, 07:53 PM posted to rec.aviation.owning
mikem
weekend. Thanks.
Best Regards,
Mike,
Search old "owning" posts. I wrote this: http://tinyurl.com/ypp4rs
MikeM
Old September 2nd 07, 02:19 AM posted to rec.aviation.owning
Mike Noel
Thanks for the replies. I'll complete this thread by explaining what was
necessary to get the audio from the 496 into the 403mc. I added a 1/8 inch
stereo jack to the panel to plug the Garmin-provided 1/8 inch audio patch
cable into. At first I soldered a wire between pin 18 of the intercom cable
and the center conductor of the 1/8 inch audio jack. In that configuration
I had to pull the 1/8 inch plug partially out to get the bitchin Betty
warnings into the intercom. After moving the audio wire from the middle to
the end conductor on the jack, bitchin Betty worked as expected with the
plug pushed fully into the jack. The xm audio signal worked in both
positions but of course was sans stereo because of the mono intercom.
The warnings from the 496 in a pleasant female voice add an interesting
level of technical sophistication to the cockpit environment. So far I've
been told '500 ft' on final approach, heard 'Caution, terrain' when flying
past high terrain, 'Warning, terrain, pull up!' when flying toward high
terrain, 'External power lost' when pulling the power plug, and 'Sink rate,
pull up!' when flying a steep final approach .
Best Regards,
"mikem" wrote in message
audio
next
weekend. Thanks.
Best Regards,
Mike,
MikeM
audio panel/impedance mismatch question Peter R. Owning 9 June 24th 06 10:53 PM
Poor Audio Quality, FlightCom 403 Stereo Intercom mikem Owning 5 April 17th 06 04:40 PM
Audio panel observation/question Mike Noel Owning 0 January 12th 06 03:35 AM
A Public Domain Disclosure- A Passive Counter-rotating Auxillary Propellor. [email protected] Piloting 11 March 26th 04 02:44 AM
Garmin audio panel question Brinks Owning 1 September 10th 03 08:41 PM
