A real head-scratcher
Old September 4th 07, 04:14 AM posted to rec.aviation.owning
Jay Honeck
Default A real head-scratcher
So we hop in the plane yesterday for the 50 minute flight to
Janesville, WI, and I notice that the display on our JPI EDM-700
engine analyzer looks funny.
Some of the LED numbers are missing pieces. Most are not. All the
vertical graph/bars appear to be fine.
Now for the odd part: The missing segments of the LEDs are NOT
consistent. For example, the same section of LEDs might improperly
display an "8" with a couple of missing segments on the right side of
the 8 -- but the next second it will change to a "9" and those right-
side segments will appear normally!
It's almost like the internal programming for the display of numerals
is screwed up, rather than the display itself?
Any theories here? I was hoping it would cure itself (ha!), but it
was the same on our flight today....
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old September 4th 07, 11:11 AM posted to rec.aviation.owning
Bob Noel
In article . com,
loose internal connection?
Bob Noel
(goodness, please trim replies!!!)
Old September 4th 07, 11:18 AM posted to rec.aviation.owning
kontiki
Could be moisture... it does interesting things to
little electronic circuits. The display on my Kx155
can do the same thuing for 30 seconds or so when
I first turn it on when in very humid weather.
Old September 4th 07, 02:13 PM posted to rec.aviation.owning
Jim Burns[_2_]
That was my first impression. It's been pretty humid around here.
"kontiki" wrote in message
Old September 4th 07, 11:51 AM posted to rec.aviation.owning
Ron Natalie
What's the bus voltage like? The first sign of a low voltage
situation on several planes I flew was that the KX155 displays
started losing segments.
Old September 4th 07, 06:50 PM posted to rec.aviation.owning
Jay Honeck
Hmmm. I didn't notice anything amiss, but I can't tell you exactly
(despite having not one, but TWO digital volt/amp meters in the
panel). I'll check that next time we fly.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old September 4th 07, 12:29 PM posted to rec.aviation.owning
B A R R Y[_2_]
Jay Honeck wrote:
Any theories here?
Loose connection or cold solder joint.
Old September 4th 07, 07:27 PM posted to rec.aviation.owning
Jay Honeck wrote:
[JPI EDM-700 engine analyzer missing seven-segment display segments]
Disclaimer: This is based on experience with ground vehicles and
equipment. I don't have an A&P; I don't even have a TG&Y. Your mileage
may vary.
I'm going to add my vote for a bad connection or cold solder joint
internal to the analyzer.
The time-honored diagnostic is to thwack it with your finger and see
if the display changes.
If you're feeling adventurous, temperature-cycle it to see if the
display changes. Like: go to the hangar at 6 AM after the plane has
been sitting all night, turn on the master, and check the display.
Then, put your calibrated fingertip next to the display, and very
carefully direct a hair dryer (on low) at the display to see if it
changes. If your finger gets too hot for comfort, shut off the hair
dryer.
It's not _impossible_ for the internal programming to change on its own,
but it's highly _improbable_.
may vary.
Matt Roberds
Old September 4th 07, 09:23 PM posted to rec.aviation.owning
Dan Luke[_2_]
If that fails, try time-honored diagnostic #2: unplug the unit and plug it
back in to reseat the connectors.
Dan
T-182T at BFM
Old September 4th 07, 11:26 PM posted to rec.aviation.owning
Jay Honeck
Well, I've tried whacking it (of course!), to no avail.
Luckily, my next planned upgrade was to install the outside air
temperature probe for the EDM-700, which will mean pulling the unit
out of the panel anyway. It's a real SOB to get at, so I suppose I
should be thankful that it chose now to go screwy...
Once it's out, we can play with it a bit more. I'm betting that I
have to send the danged thing back to JPI...
Jay Honeck
Iowa City, IA
Pathfinder N56993
Head on Maple1 Aviation Photos 1 August 3rd 07 06:02 AM
Head Scratcher john smith Piloting 10 December 31st 06 04:20 PM
FS: Real Bicycle Seats for Real People! [email protected] Aviation Marketplace 0 February 22nd 06 10:24 PM
DOT head has got to go JJ Piloting 17 July 22nd 04 05:53 PM
Real-time real world air traffic in flight sims Marty Ross Simulators 6 September 1st 03 04:13 AM
