Out-of-calibration transponder operation
Old September 13th 07, 06:12 PM posted to rec.aviation.owning
Jim Stewart
Default Out-of-calibration transponder operation
I was thumbing through the FAR/AIM last night,
trying to fall asleep and I noticed something
that I couldn't understand.
It appeared (in my half-asleep state) that the
FAR says not to operate an out-of-calibration
transponder at all, and the FAR says to operate
it with altitude reporting off.
On the face of it, the FAR would have the authority
of law behind it. Any clarification?
Old September 13th 07, 06:20 PM posted to rec.aviation.owning
Jim Stewart
Should say AIM
Old September 13th 07, 07:41 PM posted to rec.aviation.owning
JGalban via AviationKB.com
[quoted text clipped - 3 lines]
Should say AIM
Since you didn't reference any particular passages, I'll take a blind stab
at this one.
There is an FAR that says you should not operate a transponder that has not
had a certification within the last 24 months. While FARs don't have the
authority of law, they do have the authority of regulation.
I'm guessing that the AIM reference you're talking about is the one that
refers to your turning off altitude reporting if ATC notes that the reported
altitude differs from actual altitude. In that case, it's a temporary
measure to allow ATC to contiue seeing your aircraft on their scope on that
particular flight. You still need to get the problem checked out. You can't
just keep flying around with the Mode/C turned off.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200709/1
Old September 13th 07, 08:33 PM posted to rec.aviation.owning
Gig 601XL Builder
JGalban via AviationKB.com wrote:
You can't just keep flying around with the
Mode/C turned off.
You can if you aren't in an area that requires Mode/C can't you?
Old September 13th 07, 08:51 PM posted to rec.aviation.owning
Mark Hansen
Mode/C turned off.
Have a look at FAR 91.215, especially paragraph (c): Transponder-on operation:
"While in the airspace as specified in paragraph (b) of this section or in all
controlled airspace, each person operating an aircraft equipped with an operable
ATC transponder maintained in accordance with §91.413 of this part shall operate
the transponder, including Mode C equipment if installed, and shall reply on the
appropriate code or as assigned by ATC."
Although paragraph (b) refers to the airspace where Mode C is required, I read the
"or" in the above sentence to mean: "if you're in controlled airspace (A, B, C, D
or E), and your transponder support Mode C, you must have Mode C turned on."
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old September 13th 07, 09:04 PM posted to rec.aviation.owning
Mode/C turned off.
I guess it depends on how you interpret the letter of the law. I think
it's clear that you're OK in class G airspace. FAR 91.215(c) says you
should have it on (with mode C) in all controlled airspace if so equipped and
operable. I suppose you could get out of the requirement by claiming that
the mode C is not operable. In that case, I guess you'd have to placard the
unit in accordance with the regs.
Here's FAR 91.215(c) :
"Transponder-on operation. While in the airspace as specified in paragraph (b)
of this section or in all controlled airspace, each person operating an
aircraft equipped with an operable ATC transponder maintained in accordance
with Sec. 91.413 of this part shall operate the transponder, including Mode C
equipment if installed, and shall reply on the appropriate code or as
assigned by ATC."
In real life, if you're operating in an area where Mode C is required and
your Mode C isn't working, you will often get a letter from the FSDO asking
what you did to rectify the situation.
Old September 13th 07, 09:15 PM posted to rec.aviation.owning
Jim Stewart
Mode/C turned off.
assigned by ATC."
Class G is what I was wondering about. With
an out-of-calibration transponder in G is it
better to leave it off or put it in normal
mode?
60 Days for Calibration [email protected] Soaring 7 May 1st 06 03:00 AM
IGC badge calibration [email protected] Soaring 8 May 2nd 05 05:32 AM
EW Model D Calibration Wayne Paul Soaring 3 January 15th 05 01:06 AM
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
Volkslogger Calibration Ray Lovinggood Soaring 5 September 13th 03 04:56 PM
