PIK 20 D Annual Inspection
Old September 23rd 07, 07:22 AM posted to rec.aviation.soaring
Default PIK 20 D Annual Inspection
PIK 20 D owners, can you give me some advice regarding how to
lubricate all controls? My rudder pedals are pretty stiff- I have to
press pretty hard to move the rudder. Is there any way to lubricate
it, or is that normal? Also, I have a problem with the horizontal
stabilizer, it doesn't want to go on easy and then doesn't want to
come off either. Is there any tricks to that?
I have the wings going on and off pretty good, I keep a little space
between the wing and fuselage to see if pins are aligning, and it
works fine, but the horizontal stabilizer doesn't want to work well it
even makes some cracking noises when I try to take it off. Service
manual says to use grease press to lubricate, where are the fittings
for that?
Any help would be greatly appreciated. Thanks.
Chris
Old September 23rd 07, 07:06 PM posted to rec.aviation.soaring
Peter McKenzie-Brown
Get a Qualified engineer to inspect the PIK and don't
fly it until you have!
Old September 23rd 07, 07:36 PM posted to rec.aviation.soaring
On Sep 23, 10:06 am, Peter McKenzie-Brown
I will have A&P work on it,I just want to get as much info as I can.
Old September 26th 07, 06:43 AM posted to rec.aviation.soaring
for that?
Chris
Where are you located?
Robert Mudd
Moriarty, New Mexico
2006 Annual Inspection -- Complete Jay Honeck Owning 12 March 31st 06 04:27 AM
2006 Annual -- My 8th "Owner-Assisted" Inspection Jay Honeck Owning 19 March 29th 06 02:28 AM
Pre-buy Inspection Jon Kraus Owning 49 September 1st 04 01:42 PM
Pre-buy Inspection Jon Kraus Piloting 46 September 1st 04 01:42 PM
100 Hr Inspection Scott D. General Aviation 6 August 15th 04 02:03 AM
