Voltage variation
Old September 23rd 07, 10:31 PM posted to rec.aviation.owning
Jay Honeck
Default Voltage variation
I still haven't had time to work with my A&P to remove my (newly)
flakey JPI EDM-700 unit. (As you may recall, some of the LED segments
that make up the number display are going in and out.)
Someone here suggested that it might be due to low voltage, possibly
indicating an alternator problem. I've started watching the voltage,
and have noticed something odd:
The JPI has its own built-in voltage indicator. It will usually read
13.4 or 13.5 volts. We also have a stand-alone, panel-mounted digital
voltage/amperage meter, mounted a few inches below the JPI. It
usually reads a few tenths of a volt different than the JPI. (I can't
remember if it's up or down...)
a) Is this normal? Why would they read different voltages?
b) What voltage is normal? Is 13.4 too low?
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Mooney Low Voltage [email protected] Owning 22 August 1st 05 02:01 PM
FA: 12V to 24V DC voltage converter Karl Geng, N1DL Home Built 2 April 21st 05 09:48 PM
Altimeters and air pressure variation jharper aaatttt cisco dddooottt com Piloting 22 January 12th 05 10:21 PM
magnetic variation Angus Lepper Simulators 1 September 23rd 03 07:58 AM
