Removing old contest ID?
Old October 8th 07, 07:16 AM posted to rec.aviation.soaring
Bill[_11_]
Default Removing old contest ID?
I'm sure this has been discussed in the past, but I can't find a record of
the thread.
I need to remove old painted ID from gelcoat and replace with new vinyl.
What is the best method? Acetone? Wet sanding? Other options?
Thanks much,
Bill
Posted via NewsDemon.com - Premium Uncensored Newsgroup Service
-------http://www.NewsDem
Old October 8th 07, 06:15 PM posted to rec.aviation.soaring
P. Corbett
Bill
If the contest numbers were applied using lacquer or enamel paint,
acetone or lacquer thinner will remove them easily. After you have
removed the numbers, you may still be able to see where the numbers were
due to paint in the pores of the gel coat. Some light wet sanding should
solve that problem. If the numbers were applied using an epoxy paint,
solvents are practically useless and the numbers must be wet sanded off.
Be sure that there is plenty of ventilation while using these solvents.
Paul
of the thread.
Thanks much,
Bill
Old October 9th 07, 07:45 AM posted to rec.aviation.soaring
If the gel coat around the ID is cracked or in otherways in poor
condition do not use solvent. The stained solvent will wick into the
cracks and you have to sand off the gel coat to remove the color.
If the gel coat is cracked just start wet sanding with water.
Robert Mudd
Moriarty, New Mexico
Old October 9th 07, 08:29 PM posted to rec.aviation.soaring
Craig[_2_]
On Oct 8, 10:45 pm, "
Robert Mudd
If you're sanding, use a hard sanding block to avoid taking off too
much of the surrounding gelcoat. A soft block just conforms to the
underlying surface and doesn't focus the work on the high areas.
Craig
Old October 11th 07, 02:03 AM posted to rec.aviation.soaring
If sanding is what you need to do, it helps to place masking tape
around the outlines of the letters. That prevents sanding the edges of
the letters (and adjacent gelcoat/LPU) more than the center. Once you
have most of the letters sanded off you can remove the tape for the
finishing touches.
Old October 12th 07, 06:20 AM posted to rec.aviation.soaring
Bill[_11_]
"Bill" wrote in message
the thread.
Thanks, all, for the tips. The "operation" was successful (except for the
"ghost letters" in the gel coat).
Bill
-------http://www.NewsDemon.com------
Unlimited Access, Anonymous Accounts, Uncensored Broadband Access
Removing RTV John Home Built 6 October 31st 06 11:07 PM
Removing Ethanol from Gas? Jay Honeck Piloting 67 August 16th 06 04:29 PM
Removing Decals [email protected] Home Built 85 September 10th 05 12:58 AM
Removing old antennas Jay Honeck Owning 30 March 21st 04 05:34 PM
Removing Old Contest Numbers Milan Air Soaring 5 November 25th 03 01:59 AM
