EFIS eGYRO Electronic Horizon
Old October 8th 07, 08:38 AM posted to rec.aviation.soaring
Geoff Vincent
Default EFIS eGYRO Electronic Horizon
Hi all,
Does anyone have (preferably) first-hand knowledge or experience with
an EFIS eGYRO-2 Electronic Horizon? It looks like an ideal
replacement for my aging T&S.
Geoff Vincent
Old October 8th 07, 04:37 PM posted to rec.aviation.soaring
Richard[_1_]
On Oct 7, 11:38 pm, Geoff Vincent
Hi all,
Geoff Vincent
Geoff,
I have a line of electronic Gyros MGL Avionics
http://www.craggyaero.com/mgl_avionics.htm
I have flown with the Horizon and compass and it does work well, but
like all others with this technology are not TSO.
In my opinion they are much better that the Tru-Track that only gives
a light when pitch or bank is over +/_ 30 deg.
Richard
www.craggyaero.com
Old October 8th 07, 08:34 PM posted to rec.aviation.soaring
John Smith
I would like to second that question. I'm talking serious cloud flying.
Can it safely be done with the eGYRO-2, or is it just sort of an
emergency backup?
Old October 10th 07, 10:28 PM posted to rec.aviation.soaring
bumper
"Richard" wrote in message In my opinion they are
Richard
www.craggyaero.com
I guess you aren't referring to the Tru-Trak
http://www.trutrakflightsystems.com/instruments.htm
It has no lights, gives excellent bank info (no pitch info) and can be left
off until needed as it "erects" within 3 seconds even if you're cranked over
in a steep turn. It's available in a 1 minute turn rate version (best for
gliders) and costs about $450 USD. I'm happy with mine.
bumper ZZ (reverse all after @)
"Dare to be different . . . circle in sink."
Quiet Vent kit and MKII "high tech" yaw string.
Old October 11th 07, 02:58 AM posted to rec.aviation.soaring
Richard[_1_]
Richard
www.craggyaero.com
Bumper,
I am not speaking of the Tru-Trak turn and bank and would not expect
the turn and bank to be used as a horizon.
I am speaking of the Tru-Trak ADI that gives light indications when
pitch and bank are over 30 deg.
I consider the MGL to be more informative at all pitch and bank
angles.
Richard
www.craggyaero.com
Old October 11th 07, 01:45 PM posted to rec.aviation.soaring
Gary Emerson
Hi all,
Geoff Vincent
Geoff,
Richard
www.craggyaero.com
Richard,
Is the MGL such that you could leave it off for an entire flight, but
turn it on if you suddenly became concerned that you might need it? If
so, how much time does it take to "come up".
Gary
Old October 11th 07, 03:53 PM posted to rec.aviation.soaring
Richard[_1_]
On Oct 11, 4:45 am, Gary Emerson wrote:
Hi all,
Geoff Vincent
Geoff,
Richard
www.craggyaero.com
Richard,
Gary- Hide quoted text -
- Show quoted text -
Gary,
Technical specifications:
Display temperature range (operational): -20 to +80 degrees C
Supply voltage: +8 to +18V. +24/28V with optional pre regulator.
Supply current AV-1: 40mA/120mA (backlight off/on)
Supply current SP-3x: 100mA
Technical data SP-3hc sensor package. Other versions of these, delete
items not applicable.
IMU (Inertial measurement unit)
Technology: Three axis gyro plus two axis accelerometer. Third axis
accelerometer for special
applications available as option.
Gyro type: Coriolis force sensing using vibrating structure.
Manufactured using MEMS
technology.
Accelerometer: MEMS technology.
Gyro Bias drift: 1 degree/Minute typical (Note: without accelerometer
error compensation, gyros
only).
Recommended temperature range for operation: 10-30 degrees C. Other
temperature ranges are
possible providing sensor package is allowed to acclimatize and adjust
after power up.
Alternatively, sensor package can be user calibrated for a different
temperature rage (See offset
calibration).
Accelerometer drift: 1 degree per 10 degree C temperature change.
Horizontal position may be
set to zero by user.
Startup time: Instantaneous if in recommended temperature range. Up to
30 seconds typical if
outside of this range. Manual "fast set" available.
Maximum rate of turn: 165 degrees/second. Each axis simultaneously. Up
to 180 degrees/second
typical when operated in recommended temperature range (not
guaranteed, typical specification).
Resonance frequency of gyros: 14Khz.
Manual available at http://www.craggyaero.com/MaxiSingles.htm
Total power usage 140 mA. I just turned one on and it indicated in
about 6 seconds. It was within the temp range specified. The sensors
does have an internal heater.
I would turn the instrument on much earlier as the power usage is low.
Richard
www.craggyaero.com
Electronic Artificial Horizon Stuart Kinnear Soaring 14 May 3rd 07 07:56 PM
Egyro classic DavidH Instrument Flight Rules 2 November 2nd 05 12:08 AM
egyro solid state gyro DavidH Home Built 0 October 31st 05 10:23 PM
Electronic horizon? Martin Gregorie Soaring 37 September 11th 05 12:38 AM
EFIS BMA Sport G3 v GRT Horizon I alexy Home Built 0 September 14th 04 04:10 PM
