C182 Oil Temperatures
Old October 9th 07, 05:53 AM posted to rec.aviation.soaring
Steve Leonard
Default C182 Oil Temperatures
Danlj wrote:
'The volume of oil in the case isn't important in oil
cooling, it's
the oil flow through and air flow across the oil cooler
that are.'
Two items. One, 40 + years of experience in my club
with our 182 says that the oil temp is cooler if you
put in 10 quarts than if you put in 12 (the max mark
on the dip stick). Item Two, 10 quarts of oil in the
sump will have more surface area of the sump covered
with hot oil, thus there is more area for heat dissipation
through the pan with 10 quarts than with 6. I bet
it will be hotter yet with only 6 quarts onboard.
First step in solving your oil temp issue is to check
the calibration of the temp gauge. Second, try using
about 10 quarts instead of the full 12 that the dipstick
shows you can put in. Third, get out the Maintenance
Manual and see where things are in the oil cooling
system. Look for things that could restrict the flow
of oil. Fourth, make sure you have good baffles to
direct the air through the cooler, and not lust let
the air in somewhere near the cooler.
Cindy, feel free to chime in with your experiences.
Steve Leonard
How fast does the skin of the airplane cool to surrounding temperatures? Peter R. Piloting 44 December 13th 06 02:08 AM
Cool Oil Temperatures Ross and Paula Richardson Owning 11 January 12th 05 01:54 AM
Oil Temperatures Ross Richardson Owning 12 August 19th 04 07:58 PM
Bonanza Engine Temperatures Peter Shurman Owning 1 July 11th 04 06:59 PM
Withstanding Peak Temperatures O. Sami Saydjari Owning 9 March 2nd 04 03:32 PM
