How come the wings bank when I use the rudder
Old October 21st 07, 02:42 AM posted to rec.aviation.piloting
Paul kgyy
Default How come the wings bank when I use the rudder
On a 3 hour cross country today I was amusing myself by flying with
rudder pedals only (all right, OK, a little yoke usage to maintain
altitude). But then I got to wondering why applying rudder pressure
causes the plane to bank. All I could think of was that rudder usage
produces asymmetric lift because one wing is somewhat blanked by the
sideways motion induced by the rudder? Also, the rudder surface is
above the plane's center of lift but I don't know how much of a factor
that is.
Old October 21st 07, 03:07 AM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Paul kgyy" wrote in message
that is.
As you yaw, the "outside" wing is flying faster than the "inside" wing and
generates more lift which gives you bank.
Geoff
Old October 21st 07, 03:16 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
that is.
It's called a yaw/roll couple. As you create yaw you acellerate the
outside wing which then has more lift. It raises coupling with roll and
you have turn.
Dudley Henriques
Old October 21st 07, 03:36 AM posted to rec.aviation.piloting
Andrew Sarangan
that is.
In addition to what others have said, another interesting question to
ponder is why the airplane yaws when you bank.
Old October 21st 07, 03:54 AM posted to rec.aviation.piloting
"Andrew Sarangan" wrote in message
'cause if it didn't, your feet would have nothing to do ;-)
Geoff
Old October 21st 07, 04:59 AM posted to rec.aviation.piloting
The yaw is induced by the ailerons, so the only time you need to apply
rudder is when you are changing your bank angle with the ailerons. On
the side where the aileron is down, the wing has more lift, and more
drag. On the other side, the lift is spoiled and there is less drag.
The draggy wing yaws backwards, requiring opposite rudder.
This is why when you initiate a bank, you need to apply rudder in the
direction of the bank while the ailerons are in use, but not once you
stabilize the bank and neutralize the ailerons. When you roll back
wings level, you need to apply rudder the other direction to once
again compensate for the ailerons.
Dean
Old October 21st 07, 05:21 AM posted to rec.aviation.piloting
vincent norris
The rudder causes the airplane to yaw; one wing goes faster, generating
more lift; the other wing goes slower, generating less lift.
vince norris
Old October 21st 07, 06:15 AM posted to rec.aviation.piloting
Montblack
("Capt. Geoffrey Thorpe" wrote)
http://www.ercoupe.org/images/37.jpg
That would be awful...! :-)
Montblack
Old October 21st 07, 06:17 AM posted to rec.aviation.piloting
Bob Clough
What gives, guys? Good question followed by three answers that
actually agree? What's up with that? Where's the usenet controversy?
Bob
generating more lift; the other wing goes slower, generating less
lift.
vince norris
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Old October 21st 07, 07:13 AM posted to rec.aviation.piloting
BT
Isn't interesting that entry level RC Aircraft only have rudder and elevator
controls.. and then turn just fine.
Funny that a full sized airplane would react the same way.
In a stall, you pick up the low wing with rudder, not aileron, that only
adds adverse yaw, more drag on the low wing, and fights the rudder.
BT
that is.
GPS instead of turn and bank Danny Deger Piloting 52 February 8th 07 03:03 PM
X-Wings and Canard Rotor Wings. Charles Gray Rotorcraft 1 March 22nd 05 01:26 AM
Bank Check Aviation Ron R Piloting 68 January 19th 05 02:30 AM
BREAKING THE BANK Cribsheet Piloting 0 December 22nd 04 07:27 PM
key bank CSA722 Piloting 0 July 14th 03 08:04 AM
