Re-shaping fiberglass parts with heat
Old October 29th 07, 08:28 PM posted to rec.aviation.soaring
JJ Sinclair
Default Re-shaping fiberglass parts with heat
I knew the concept was valid from Schempp-Hirth instructions on how to
heat up an early Cirrus wing and put in the twist that Cirrus's after
s/n 175 had. I have a badly twisted gear door (corner stood proud a
good 5mm), so I thought I'd give it a try on a much smaller scale. I
held the gear door in front of an electric space heater for a good 8
minutes, until it was too hot to leave a finger on the surface. Then I
put it in place on the wheel-well (fuselage inverted) and held the
ends with two 25# shot bags. I slipped in a 5mm shim to achieve over-
twist for the expected spring-back. Let it cool for an hour and it
fits like new!
Anybody else have experience heat-twisting epoxy/fiberglass parts?
What's the yield temp?
JJ
Fiberglass seperation Lou Home Built 7 September 25th 06 05:03 AM
Aluminized fiberglass Dan, U.S. Air Force, retired Home Built 2 May 3rd 05 09:35 AM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Home Built 0 January 10th 04 03:20 AM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Aviation Marketplace 0 January 10th 04 03:20 AM
2004 California airshow season shaping up! Wings Of Fury Military Aviation 0 December 31st 03 06:34 AM
