metar slp reading?
Old November 5th 07, 10:30 PM posted to rec.aviation.piloting
Paul kgyy
Default metar slp reading?
Some metars report a Sea Level Pressu who uses the "slp"
information, and why?
Old November 5th 07, 10:49 PM posted to rec.aviation.piloting
TheSmokingGnu
Seaplanes/amphibians, aircraft with millibar altimeters, analysis of
current pressure gradients vs. "standard" (?)
TheSmokingGnu
Old November 5th 07, 11:12 PM posted to rec.aviation.piloting
quietguy
SLP reports are the way meteorologists compensate for elevation
differences among the reporting stations; when SLP rather than station
pressure is plotted on a synoptic map the high and low pressure
centers can be accurately tracked even as they cross mountain ranges.
Old November 6th 07, 12:32 AM posted to rec.aviation.piloting
Dallas
Maybe I'm missing something... Aren't all pressures reported in METARs
corrected to sea level?
Dallas
Old November 6th 07, 01:32 AM posted to rec.aviation.piloting
quietguy
In aviation weather observations, yes; in the data coming over the
wire to weather forecast offices and data processing centers, station
pressures are also reported by WMO-designated synoptic reporting
stations. Even though station pressures aren't disseminated to
aviators the SLP is marked so there'll be no confusion over what sort
of pressure it is.
Old November 6th 07, 04:26 AM posted to rec.aviation.piloting
Dallas
of pressure it is.
It's nice they endeavor not to confuse us.
For instance they code 998.2 hectopascals to SLP982 so they don't confuse
anyone.
Dallas
Old November 6th 07, 03:45 PM posted to rec.aviation.piloting
The Visitor[_2_]
Well put!
Old November 6th 07, 05:29 PM posted to rec.aviation.piloting
Andrey Serbinenko
Metar's "altimeter" pressure is a value such that if you set your
altimeter to it on the ground, it will show your elevation above MSL.
Altimeter's mechanism assumes standard atmosphere where pressure changes
with altitude linearly: it doesn't take into account possibly non-standard
temperature. SLP, on the other hand, does similar reduction of station's
barometric pressure to MSL, but adjusts it for non-standard station
temperature.
Andrey
Old September 7th 12, 12:49 AM posted to rec.aviation.piloting
thanks for the good discussion.
METAR from Mexico Przemek Piloting 2 October 21st 05 03:45 AM
Metar Report [email protected] Instrument Flight Rules 12 August 22nd 05 12:12 PM
how can you get live METAR data ? Bravo Piloting 13 November 5th 04 07:19 AM
Interesting METAR Nathan Young Piloting 1 May 15th 04 04:37 PM
No METAR Data at AOPA and NWS? Scott Lowrey Piloting 4 March 3rd 04 08:19 PM
