I think we all know what old aluminum planes look like. But what do
old composite planes look like? Are they less susceptible to hanger rash and faded paint? -Curious -Charles Talleyrand |
![]() "Charles Talleyrand" wrote in message oups.com... I think we all know what old aluminum planes look like. But what do old composite planes look like? Just visit any gliderport. Glass gliders have been popular for decades now. Are they less susceptible to hanger rash and faded paint? No! One thing that has been learned is that gellcoat is generally something to be avoided. To refinish gellcoat, one must first carefully wetsand the entire original coating out of existince withuout sanding away any structure. This a process that can cost several tens of thousands. Some gliders are actually shipped to eastern block nations for the job due to cheaper labor costs. Newer gliders are mostly painted, rather than gellcoated. Since you mention faded paint, there are usually limitations on paint colors due to temperature rise of the structure in the hot sun. Also, composite structures are not always as stable as one would like. Some gliders have needed their wings to be expensively reprofiled due to spar shrinkage which warped the wing skins. The above list of woes should not be taken as evidence that composite aircraft structures are a bad idea. There are good reasons why virtually all new high performance gliders are now of composite construction! Vaughn |
oups.com... I think we all know what old aluminum planes look like. But what do old composite planes look like? Are they less susceptible to hanger rash and faded paint? -Curious -Charles Talleyrand A lot depends on how they are maintained and stored. Go to the local boat yard and look at the old composite boats - they date back to the '60s and most are ouside year round. Of course, many of the older boats have been re-painted. Gel coat fades /yellows as much or more than paint - but you won't find many composit aircraft that aren't white. It also crazes, cracks and chips. On the other hand, if a composite aircraft is finished with a two part polyurathane, the paint will usually hold up like it does on aluminum. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
![]() "Charles Talleyrand" wrote ... I think we all know what old aluminum planes look like. But what do old composite planes look like? Are they less susceptible to hanger rash and faded paint? Can't point to any generic difference. It comes down to maintenance I'd say. I fly a 1981 Grob motorglider and its white surface shines almost as new, especially when polished. The paint has faded appreciably more, and on the canopy plexiglass the age shows. But that affects all airplanes. Some hangar rash, like small scratches, can easily be repaired with gelcoat and sanded + polished to become invisible. More difficult are small hairline cracks in the gelcoat that may occur, for example at cutouts with too small corner radius. Not any safety issue, but tend to return if just repaired with gelcoat. I guess on newer designs the designers have learned to avoid such pitfalls. Also nowadays gelcoat is more seldom used, as paint is preferred. |
Appearance | Nyal Williams | Soaring | 4 | October 30th 06 08:52 AM |
Composite workshop | mat Redsell | Home Built | 0 | February 19th 05 02:44 PM |
Composite question OT | Steve B | Soaring | 4 | November 25th 04 07:42 PM |
F/A-22 to make appearance at U.S. Air Force Academy parade | Otis Willie | Military Aviation | 14 | June 5th 04 11:11 PM |
Composite workshop | Marske Flying Wings | Restoration | 0 | January 26th 04 12:03 AM |
