Experimental complex...?
Old November 14th 07, 07:55 PM posted to rec.aviation.piloting
soaringpilot2
Default Experimental complex...?
I've got what may be a dumb question (since I suspect the answer is
obvious), but here it goes:
If I am looking at buying an experimental homebuilt with a retractable
conventional gear; BUT under 200hp and a fixed pitch prop, do I need a
complex endorsement to legally fly, or is that just with regards to
aircraft with standard airworthiness certificates (factory built)?
I'm having an argument on FAR trivia, and was curious what people
thought.
Cheers!
Ryan in Madison
Old November 14th 07, 09:16 PM posted to rec.aviation.piloting
It doesn't matter whether the airplane is storebought or homebuilt; a
complex airplane is a complex airplane -- and the one you're
describing isn't. It needs retractable gear, flaps and a controllable-
pitch propeller to be complex. It doesn't need more than 200 hp --
that would make it a high-performance airplane, requiring a different
endorsement. But you'll need the appropriate endorsement(s) to fly a
plane regardless of its registration category.
Old November 15th 07, 12:36 AM posted to rec.aviation.piloting
BT
14CFR61.31(e) makes no distinction of factory built or home built
experimental. It just says "airplane".
It is not complex, as another stated you need flaps, controllable prop and
gear, or if a sea plane, flaps and controllable prop.
Engine Size (HP) does not make any contribution to the complex aspect.
BT
"soaringpilot2" wrote in message
ps.com...
thought.
Cheers!
Ryan in Madison
Old November 15th 07, 01:35 AM posted to rec.aviation.piloting
Dave S
thought.
Cheers!
Ryan in Madison
Retractable gear, by itself, does not a complex aircraft make. You must
have flaps, retractable gear AND an adjustable prop to have a complex
landplane.
The answer to that question is no.
The answer to the other question, does this complex endorsement apply to
standard certificates?
I cannot speak with authority, but i've been led to believe if you are
flying solo, you dont have to have category, class or endorsements
pertinent to the experimental airframe. In the past few years I believe
the Feds wanted folks carrying passengers in experimentals to have
category and class ratings and applicable endorsements..
I'm sure if im mistaken, the corrections will be quick and merciless :P
Dave
Old November 15th 07, 06:36 AM posted to rec.aviation.piloting
Andrew Sarangan
thought.
Cheers!
Ryan in Madison
Which airplane are you talking about? There was some discussion around
this topic regarding the Europa, which has a partially retracting
monowheel. Some argued it was complex, some said no. It turned out
that the insurance companies insisted that it was a complex aircraft,
so whether or not it was really complex under FAA rules became a moot
point (unless you are self-insured).
Old November 16th 07, 12:16 AM posted to rec.aviation.piloting
BT
Europa - partially retracting gear, flaps? and a feathering prop? sounds
complex to me.
BT
"Andrew Sarangan" wrote in message
thought.
Cheers!
Ryan in Madison
Old November 16th 07, 11:50 AM posted to rec.aviation.piloting
soaringpilot2
I'm talking about the Cvjetkovich CA-65 Sky Fly (there's one on
barnstormers right now).
http://www.cvjetkovic-aircraft.com/
-Ryan in Madison
FADEC = complex Bob Gardner Piloting 237 November 29th 06 01:55 AM
Is this a Complex Plane? [email protected] Piloting 12 December 7th 05 03:19 AM
Engine with Complex History Mike Granby Owning 4 August 30th 04 02:48 AM
The "Complex" TAS calculation Arnold Pieper Soaring 2 December 14th 03 12:22 PM
Complex aircraft question Robert M. Gary Piloting 5 October 17th 03 12:25 PM
