North America: Anyone have experience with this new, improved tow
hook based upon the Schweizer hook? Your FAA Approval process? From the catalog at www.aircraftspruce.com (see photos there) Aircraft Spruce Pilot Supplies - Towing Equipment GLIDER & BANNER TOW HOOKS These tow hooks are available in two models. One is a bolt-on tow hook with a mounting lug which is ideal for attachment to a tail tie down point. The other model is a weld-on tow hook designed to be directly welded to a custom mounting bracket. These two hooks are similar in design to the Schweizer manufactured two hooks that are no longer available. Design improvements were made to increase emergency release capability at all towing loads and angles. These new tow hooks have greater release arm leverage and a unique hardened roller release design to reduce release force at all tow angles. Additionally, the geometry of the tow hook housing was improved to keep the tow ring in the optimum position to minimize release force. FAA approval can be obtained for the complete tow hook and release system by following the guidelines in FAA Advisory Circular 43.13-2A, Chapter 8, titled, "Glider and Banner Tow-Hitch Installations" and the included tow hook installation instruction. Description Part No. Price GLIDER TOW HOOK (WELD ON) 13-04974 $302.81 GLIDER TOW HOOK (BOLT ON) 13-04975 $340.40 |
On Nov 22, 6:24 am, Burt Compton - Marfa wrote:
North America: Anyone have experience with this new, improved tow hook based upon the Schweizer hook? Your FAA Approval process? No experience with this release but I've noticed that some hook installations don't release until most of the release handle motion range is used up. Since this release has a longer arm then more release handle motion will be required. I wonder if that will require a redesigned release handle or perhaps just more careful attention to cable adjustment. Andy |
The roller is a huge designe improvement too, both for setting the
latch and pushing open. Would like to see a heavier guage of material on the sides. The Schweizer hooks WILL bend and/or jam with the just the right angle of side load. Michael Andy wrote: On Nov 22, 6:24 am, Burt Compton - Marfa wrote: North America: Anyone have experience with this new, improved tow hook based upon the Schweizer hook? Your FAA Approval process? No experience with this release but I've noticed that some hook installations don't release until most of the release handle motion range is used up. Since this release has a longer arm then more release handle motion will be required. I wonder if that will require a redesigned release handle or perhaps just more careful attention to cable adjustment. Andy |
Andy wrote:
No experience with this release but I've noticed that some hook installations don't release until most of the release handle motion range is used up. Since this release has a longer arm then more release handle motion will be required. I wonder if that will require a redesigned release handle or perhaps just more careful attention to cable adjustment. I've always liked the Scheder-design HP nose or chin hooks. They seem simple in design and as far as I know are quite robust. The neat thing is upon release they completely retract into the fuse and cover the opening with a flush plate. I would guess that Bob K. of HP Aircraft owns the rights to the design. I'm surprised that I don't see this hook retrofitted to a lot of other glider types. Regards, -Doug |
![]() "Doug Hoffman" no.spam wrote in message .. . I've always liked the Scheder-design HP nose or chin hooks. They seem simple in design and as far as I know are quite robust. The neat thing is upon release they completely retract into the fuse and cover the opening with a flush plate. I would guess that Bob K. of HP Aircraft owns the rights to the design. I'm surprised that I don't see this hook retrofitted to a lot of other glider types. Doug, The 1-35A, SparrowHawk and, I believe, Zuni have tow hooks simular the Dick Schreder's HP/RS series design. Wayne HP-14 "6F" http://www.soaridaho.com/Schreder |
I believe the hook described in thr Aircraft Spruce catalogue is for the
Towplane. The problem is release ability under extreme vertical or horizontal (side) loads by a very out-of-position glider. This is of great interest to towpilots. -- Hartley Falbaum "Wayne Paul" wrote in message ... "Doug Hoffman" no.spam wrote in message .. . I've always liked the Scheder-design HP nose or chin hooks. They seem simple in design and as far as I know are quite robust. The neat thing is upon release they completely retract into the fuse and cover the opening with a flush plate. I would guess that Bob K. of HP Aircraft owns the rights to the design. I'm surprised that I don't see this hook retrofitted to a lot of other glider types. Doug, The 1-35A, SparrowHawk and, I believe, Zuni have tow hooks simular the Dick Schreder's HP/RS series design. Wayne HP-14 "6F" http://www.soaridaho.com/Schreder |
Long time readers of this news group will remeber posting from me on
the subject of Tost tow hooks verses all the others. My opinion is tilll the same, nothing compairs to a Tost tow hook either on the glider or on the tow plane, for safety and reliability. As mentioned in other replys to this subject the other tow hooks have have an increase in the force needed to actuate the release that is portional to the tension on the tow line. This is not good. None of the other tow hooks have a schedule of maintaince, none of the others lock over center and hold the tow ring in a position for easy and clean release of the tow rope. The Schweizer and Schreader style hooks just can not compaire to a Tost. One reason you do not see these other tow releases retrofitted to a lot of other gliders is that except for the Schweizer gliders, they are not legal to use in Type Certificated gliders. For a Type Certificated glider that was originally fitted with a Tost hook, to have the other sype hook installed would require a fair ammount of paperwork. A knowlegable FAA inspector would not accept only a form 337 for this change. The Tost is so good that it has been copired by Ottfur in England and by SZD and other former East Block glider manufactuers. Yes, they are more expensive, but I think you really do get what you pay for, and I think that considering the tow release's critical part in safe launching, the extra cost is a small price to pay. Robert Mudd Moriarty, New Mexico Expirencing our first snow fall of the season today. I've always liked the Scheder-design HP nose or chin hooks. �They seem simple in design and as far as I know are quite robust. �The neat thing is upon release they completely retract into the fuse and cover the opening with a flush plate. I would guess that Bob K. of HP Aircraft owns the rights to the design. � I'm surprised that I don't see this hook retrofitted to a lot of other glider types. Regards, -Doug |
Robert Mudd is dead on.
I would add that there is considerable safety and operational value in standardization. On any airfield today, Tost is the dominant ringset/release system. If a second system is used, it adds ring switching to the rope handling chore. There is always a temptation to use a Tost ringset on a Schweizer which WILL occasionally jam the release. Standardizing on Tost is expensive but safer and more convenient. Bill D wrote in message ... Long time readers of this news group will remeber posting from me on the subject of Tost tow hooks verses all the others. My opinion is tilll the same, nothing compairs to a Tost tow hook either on the glider or on the tow plane, for safety and reliability. As mentioned in other replys to this subject the other tow hooks have have an increase in the force needed to actuate the release that is portional to the tension on the tow line. This is not good. None of the other tow hooks have a schedule of maintaince, none of the others lock over center and hold the tow ring in a position for easy and clean release of the tow rope. The Schweizer and Schreader style hooks just can not compaire to a Tost. One reason you do not see these other tow releases retrofitted to a lot of other gliders is that except for the Schweizer gliders, they are not legal to use in Type Certificated gliders. For a Type Certificated glider that was originally fitted with a Tost hook, to have the other sype hook installed would require a fair ammount of paperwork. A knowlegable FAA inspector would not accept only a form 337 for this change. The Tost is so good that it has been copired by Ottfur in England and by SZD and other former East Block glider manufactuers. Yes, they are more expensive, but I think you really do get what you pay for, and I think that considering the tow release's critical part in safe launching, the extra cost is a small price to pay. Robert Mudd Moriarty, New Mexico Expirencing our first snow fall of the season today. I've always liked the Scheder-design HP nose or chin hooks. ?They seem simple in design and as far as I know are quite robust. ?The neat thing is upon release they completely retract into the fuse and cover the opening with a flush plate. I would guess that Bob K. of HP Aircraft owns the rights to the design. ? I'm surprised that I don't see this hook retrofitted to a lot of other glider types. Regards, -Doug |
Bill Daniels wrote:
Robert Mudd is dead on. I would add that there is considerable safety and operational value in standardization. On any airfield today, Tost is the dominant ringset/release system. If a second system is used, it adds ring switching to the rope handling chore. There is always a temptation to use a Tost ringset on a Schweizer which WILL occasionally jam the release. Standardizing on Tost is expensive but safer and more convenient. Well, good luck getting Schweizer gliders banned from airfields unless they have a Tost conversion. But I agree that not having to hassle with switching rings on the end of the tow rope would be best. Btw, The three Schreder gliders that I have flown accepted either the Tost ring or the Schweizer ring without problems. Regards, -Doug |
Aircraft Spruce Rant | Doug Palmer | Home Built | 29 | January 7th 19 03:40 PM |
Aircraft Spruce came through for me | Rob Turk | Home Built | 3 | June 26th 07 05:01 PM |
Aircraft Spruce only keeps records for 2 years?? | Rob Turk | Home Built | 7 | June 21st 07 08:07 PM |
What Others Are Saying About Aircraft Spruce | jls | Home Built | 29 | February 18th 05 11:29 PM |
Aircraft Spruce and Jim Irwin | Larry Smith | Owning | 23 | October 13th 03 10:59 PM |
