Repainting a LARK
Old December 18th 07, 03:41 AM posted to rec.aviation.soaring
Zoltan T
Default Repainting a LARK
Does anyone have experience repainting a Lark (IS-28B2)
wing?
I know some other metal gliders have their wing profiled
with filler, so any information would be appreciated.
Zoltan
Old December 19th 07, 05:59 AM posted to rec.aviation.soaring
fred
On Dec 17, 7:41 pm, Zoltan T
wing?
Zoltan
I'd go with filling with fearher coat and Polyurethane paint applied
by a good auto shop. Preparation is the key.Not cheap but excellent
results.Fred
Old December 19th 07, 02:14 PM posted to rec.aviation.soaring
JJ Sinclair
Good advise from Fred. A metal wing with heavy filler won't
stay...............I believe the "compitition" 1-35's came with a
ceconite wrap, then polyurethane paint without the accelerator which
makes it brittle. You want the paint to remain flexable, especially on
fabric control surfaces.........I wouldn't wet-sand the
final ...........touch the ceconite and it will fray and fuzz. Most
auto body shops will do a good job, us glider repair shops load on the
paint (4 heavy coats), then wet-sand off the final coat to give that
killer performance and look of a glass bird.
Have Fun,
JJ
wing?
Zoltan
results.Fred
Old December 19th 07, 05:58 PM posted to rec.aviation.soaring
Cats
Personally I think it's easier to own & fly a glass bird!
Old December 19th 07, 09:51 PM posted to rec.aviation.soaring
On Dec 17, 10:41 pm, Zoltan T
wing?
Zoltan
Check carefully for corrosion. This is a common problem with this
ship.
Look in areas of cracked paint and wherever filler is loose or
cracked.
If it were mine, I would not fill extensively.
Good Luck
UH
Looking for a Lark IS-28B2 or IS-32 [email protected] Soaring 3 June 2nd 06 06:35 AM
Lark tail dolly Gordon Schubert Soaring 0 September 6th 05 04:56 AM
Need Trailer for 2 place Lark Tom A Soaring 7 September 16th 04 12:03 AM
Okay, I posted a photo of the Lark Badwater Bill Home Built 10 February 2nd 04 06:41 PM
Lark IS-32 Lord Struthers Soaring 0 January 26th 04 10:13 AM
