(USA) Airport data now available with Airspace files
Old December 28th 07, 07:37 AM posted to rec.aviation.soaring
Tuno
Default (USA) Airport data now available with Airspace files
In addition to the NDF-based airspace files that subscribers at
justsoar.com will receive, turnpoint files describing airports from
the current FAA NASR database will also be provided with the download.
I think this feature will be pretty useful. If you provide a turnpoint
file to the web page to specify your area of interest, with either a
Cambridge format (.dat) or SeeYou (.cup), the pair of files you get
back (in addition to the trio of airspace files) will be:
1) A copy of the turnpoint file you provided, with turnpoint records
added for all airports more than a mile away from any of the
turnpoints;
2) A turnpoint file in the alternate format, with all airport records
in the area of interest.
If you provide coordinates instead of a turnpoint file, the two
turnpoint files will of course contain all of the airports in your
AOI. So you can do business just about any way you like.
The proverbial motivating use case goes as follows:
1) Pez decides to go Parowan for the next Region 9 contest, along with
everything else.
2) Pez uses parowan4.cup, from John Leibacher's site, to get the
latest FAA airspace and airport data from justsoar.com.
3) Pez installs the .cup file from justsoar.com on his PDA for SeeYou
Mobile, and the .txt airspace file in SeeYou desktop to create
airspace data for his SeeYou Mobile.
4) With peace of mind at having the latest FAA airspace and airport
data, Pez blazes to win the sniffer class. His friends are amazed and
he gets the girl, just like I did.
(The above, of course, is not a promotion for SeeYou Mobile. A similar
use case for WinPilot applies. And XCSoar ... and GNII ...)
It was, of course, a shameless plug for justsoar.com, brought to you
by my newest crewmember, Ian Mitchell (2 December, 4 pounds 12 ounces,
released from tow six weeks early but climbed out of the hole on a 12
knotter like he was never in trouble).
Go fly.
~ted/2NO
Old December 28th 07, 07:34 PM posted to rec.aviation.soaring
fcnorton
turnpoints;
everything else.
Go fly.
~ted/2NO
Congratulations Ted!
On both the site and the new member of the ground crew!
I look forward to using the site in the upcoming season.
Happy New Year!
FC Norton
Digital airspace data question -- any FAA data gurus out there? Tuno Piloting 2 December 27th 07 06:06 PM
Replacement for DAFIF Airspace Data 2KA Soaring 17 December 26th 07 05:17 AM
(USA) Soaring airspace files from NFD -- now available Tuno Soaring 11 December 23rd 07 05:15 PM
DAFIF data for creating SUA files [email protected] Soaring 0 November 7th 07 03:36 PM
Load airspace files into emap Jon Marshall Soaring 0 August 14th 05 09:56 AM
