(USA) Interesting FAA data
Old January 3rd 08, 03:13 AM posted to rec.aviation.soaring
Tuno
Default (USA) Interesting FAA data
Interesting airport numbers from the FAA's NASR datamabase:
FacilityType Count
AIRPORT 12641
BALLOONPORT 15
GLIDERPORT 34
HELIPORT 5413
SEAPLANE BASE 497
STOLPORT 80
ULTRALIGHT 135
Total 18815
That's 12875 air/gliderports alone!
In case you're wondering, 12675 of those have described runways.
The number of runways in the air/gliderports:
1 10391
2 1831
3 356
4 72
5 15
6 8
7 1
8 1
I wonder which airport has 8 runways?! (I am not going to check.)
2NO
Old January 3rd 08, 03:32 AM posted to rec.aviation.soaring
jeplane
I am sure there are others, but San Francisco, ca fits the bill with 8
runways.
Most commercial airports actually have mo Denver, CO= 12 runways,
Long Beach, CA= 10 runways
for example...
Old January 3rd 08, 03:58 AM posted to rec.aviation.soaring
cfinn
runways.
for example...
I think in this case they are counting both ends of a landing surface
(ie. Rwy 9 & 27) as a single runway for the statistics, considering
the maximum number of runways listed is 8.
Old January 3rd 08, 04:36 AM posted to rec.aviation.soaring
Tuno
That's krekt. The database shows Denver with 6 and LGB with 5.
Old January 3rd 08, 01:55 PM posted to rec.aviation.soaring
jeplane
Well then, I am curious!
Which airport in the US has 8 runways (or 16 depending where you are
coming from?)
Old January 3rd 08, 04:53 PM posted to rec.aviation.soaring
Tuno
Which airport in the US has 8 runways...
The national centerline champion is, well, unique. All eight runways
are 1800 by 150 feet. And the airport is completely symetrical around
four axis.
It is owned by the Navy, in Florida:
http://maps.google.com/maps?f=q&hl=en&geocode=&time=&date=&ttype=&q=N30%C 2%B037'00%22+W087%C2%B008'00%22&ie=UTF8&ll=30.6253 94,-87.139521&spn=0.026958,0.046349&t=h&z=15&om=1
(No doubt you'll need to reassemble the above link to make it work.)
The airport with "only" seven runways is DFW, with three of them at
13400' in length.
Old January 3rd 08, 02:30 PM posted to rec.aviation.soaring
Gary Emerson
If they are counting both ends of the runway, then I'm curious about the
one's with 1, 3, 5, and 7.......
Old January 3rd 08, 03:07 PM posted to rec.aviation.soaring
Cats
One runway with two landing directions = 1 runway in their
statistics. If each direction was counted separately they would all
be even numbers.
So the airport with 8 runways has up to 16 landing directions, but 8
bits of solid stuff on the ground.
Old January 3rd 08, 04:16 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
I've read about an experimental circular runway being built in the USA
during the '20s or '30s:
- where it was
- does it still exist
- how many runways should it be counted as in this database?
Enquiring minds want to know.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 3rd 08, 05:16 PM posted to rec.aviation.soaring
chris
On Jan 3, 10:16*am, Martin Gregorie
Speaking of which, I've been wondering how easy it would be to land in
a curved field. Is there much special technique to landing on a
curved field with trees on the sides? I suppose the biggest challenge
would be to touch down at the right spot tangent to the curve and keep
the right bank angle in through the pattern all the way to the stop.
Suppose somebody could try it on a big square field.
Not dragging the inside wing would be the biggest challenge, maybe a
high wing glider like a K-8 would be easier.
Chris
Digital airspace data question -- any FAA data gurus out there? Tuno Piloting 2 December 27th 07 06:06 PM
Flight Data recorders on a 757 - What data? Al Dykes General Aviation 0 January 1st 07 06:09 PM
Some interesting data from today's Washington Post...re general aviation pilot numbers Stewart Kissel Soaring 2 July 28th 06 11:59 PM
OT, but very interesting. Flyingmonk Piloting 11 January 16th 06 04:48 AM
interesting aluckyguess Piloting 11 October 28th 04 12:10 AM
