Weight and balance, ballast, trim when flying alone
Old January 15th 08, 06:53 PM posted to rec.aviation.piloting
Mxsmanic
Default Weight and balance, ballast, trim when flying alone
What is your method for handling weight and balance when you are piloting a
small aircraft alone? Do you just trim to adjust for the lateral imbalance,
or do you put something on the other side of the plane (ballast, luggage,
etc.) to balance it out, or what?
Old January 15th 08, 07:03 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
piloting a small aircraft alone?
lateral imbalance, or do you put something on the other side of the
plane (ballast, luggage, etc.) to balance it out, or what?
Why, you thinking of becoming ballast?
you're overqualified.
Bertie
Old January 15th 08, 07:40 PM posted to rec.aviation.piloting
John[_13_]
What is your expectation from your simulator experience? Do you need to
laterally balance the plane in MSFS? Since that is all you seem to be
interested in, that's what you should be considering.
"Mxsmanic" wrote in message
a
imbalance,
Old January 15th 08, 07:59 PM posted to rec.aviation.piloting
Robert M. Gary
small aircraft alone? *Do you just trim to adjust for the lateral imbalance,
What a very, very odd question. I don't believe I've ever been asked
such a question by a student before.
-Robert, CFII
Old January 15th 08, 08:03 PM posted to rec.aviation.piloting
LOL.
Oh that's a good one. Sheet ...
Old January 15th 08, 08:12 PM posted to rec.aviation.piloting
Rip[_2_]
Just tilt your big fat head to the high side, and stick a book under
your monitor to compensate.
Old January 15th 08, 08:24 PM posted to rec.aviation.piloting
Gig 601XL Builder[_2_]
While I'm sure you are going to argue some point of this response I'll
post for those that come later.
It completely depends on the plane. In a 172 it really isn't an issue.
Fuel burns out of each wing tank at about the same rate and I've never
noticed a difference in need for aileron trim with two as opposed to
one. Which is a could thing because I've never seen a 172 with aileron trim.
On the 601XL I'm building most builders are installing aileron trim
because with just one person on-board some of the planes are a little
left wing heavy.
Also on planes that don't draw fuel equally from both wings you have to
switch tanks to keep the aircraft balanced. 150 lbs of fuel 4 feet out
on the wing has a LOT more effect on the balance of the aircraft than
200 lbs of meat near the center line.
Old January 15th 08, 08:52 PM posted to rec.aviation.piloting
Kloudy via AviationKB.com
Bertie
niiiice...
actually some of these are pretty good.
"underqualified" might be what I'd expect from you, yip.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200801/1
Old January 15th 08, 08:58 PM posted to rec.aviation.piloting
Mxsmanic
John writes:
I expect it to reasonably simulate weight and balance issues, which it does,
but not having flown the real thing, I don't know how accurate the simulation
is. I've read that MSFS tends to exaggerate the W&B effects of unequal
amounts of fuel in the tanks, for example, although I always keep fuel loads
balanced.
Do you need to laterally balance the plane in MSFS?
Yes.
Mxsmanic
Robert M. Gary writes:
Is that why you haven't answered it?
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 02:54 AM
Weight & Balance DVD jon Home Built 0 October 8th 05 06:39 PM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 06:11 PM
Weight and Balance JP Piloting 2 January 13th 04 11:54 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 03:57 AM
