Traffic warning devices
Old January 23rd 08, 04:02 AM posted to rec.aviation.soaring
AK
Default Traffic warning devices
Does anyone have any experience with one of these devices?
PCAS XRX $1795
PCAS MRX $549
Is there enough value in XRX's ability to show direction?
Last year I flew a plane from NH to PA. I had a Garmin 430 with
traffic. I was at 8,000 feet and about 80 nm west of New York City
when the instrument warned me about a potential collision with a fast
moving aircraft. I had to dive to avoid collision and with my family
on board it was not a good experience. The worst part was that I was
assigned a transponder code and I used flight following. It seems our
ATC is quite broken these days.
Anyway, I am looking for traffic warning device for my glider. If XRX
is worth the price I will buy it, but in a glider I am not sure it
makes a difference, especially while circling. Please share your
experience.
AK
Old January 23rd 08, 04:53 AM posted to rec.aviation.soaring
Darryl Ramm
Search the archives and you should find quite a few favorable mentions
of the MRX. I'm not sure how practical the XRX would be in a
sailplane. It is relatively large/cumbersome - where would you put it?
has a cooling fan etc. and draws considerably more power than the MRX.
With the MRX warning induced scanning for traffic sees to work well,
false positives are not an issue.
Darryl
PCAS XRX $1795
PCAS MRX $549
experience.
AK
Old January 23rd 08, 05:56 AM posted to rec.aviation.soaring
Randy[_2_]
AK,
I have been using the PCAS MRX for almost 2 years and am really
pleased with this product.
Since I purchased my MRX, I have had to send it back because it had
stopped working (Bad
Filter??). I had it fixed/replace within a weeks time. Two members
have also purchased this item
and have not had any problems.
Randy
N304RS
www.tulsasoaring.com
Old January 23rd 08, 02:44 PM posted to rec.aviation.soaring
We have installed several MRX devices in gliders, and I have one top
center on my Duo instrument panel. They really work!
Understand they only detect other aircraft with a working transponder,
however these fast movers are the aircraft I am most concerned about.
Many aircraft also have devices to detect other aircraft with
transponders, so my Duo also has a transponder.
Tom Knauff
Knauff & Grove Soaring Supplies
www.eglider.org
Old January 23rd 08, 04:05 PM posted to rec.aviation.soaring
jeplane
I have been using the MRX for over a year now.
Yes it has been a good equipment to have.
My only gripe however, is about the rate it finds a traffic. There has
been a few times where I saw a target well before the MRX picked it
up. Also, I found the altitude where it shows the traffic not entirely
reliable. But then, it must be because of the target's transponder,
which could differ by a few hundred feet itself, and also the rate of
climb or descent you get while circling.
For example, if the unit tells you that a traffic is 300 feet above
you, you better start scanning +-200 feet from that.
I also used it in airplanes in busy areas like in the Los Angeles
basin and Phoenix airspace, and it is nearly useless, as it picks up
too many targets!...:-)
However, it is largely compensated by the fact that it did pick up
traffics when I had no clue they were there, 98% of the time.
Richard Depinay
Phoenix, AZ
Old January 23rd 08, 04:35 PM posted to rec.aviation.soaring
Andy[_1_]
PCAS XRX $1795
PCAS MRX $549
I use the MRX in my PA28-180 and in my sailplane. I am pleased with
the performance of the MRX and would not hesitate to recommend it.
The only issue I am aware of with using the MRX in a sailplane is that
it will continuously alarm if you thermal with a transponder equipped
glider. This means you have no protection from other traffic. Zaon
was requested to add intelligent muting capability but says the
processor is not powerful enough to implement that.
I would not consider an XRX for sailplane use. It's too big.
To answer jeplane's comment - I also fly in the Phoenix area (DVT
based) and, with the alerting volume set small, I find it very useful.
Andy
Old January 23rd 08, 06:20 PM posted to rec.aviation.soaring
Mike Schumann
If you are going to the SSA Convention, join us at 4PM on Wed, 2/13 for a
session on FLARM / ADS-B and Collision Avoidance.
Mike Schumann
"AK" wrote in message
PCAS XRX $1795
PCAS MRX $549
experience.
AK
Posted via a free Usenet account from http://www.teranews.com
Old January 23rd 08, 10:51 PM posted to rec.aviation.soaring
Vaughn Simon
PCAS XRX $1795
PCAS MRX $549
Thanks for bringing up this subject. I see that they have finally added an
audio output jack/headset cable to the MRX. Without that feature, I considered
the MRX to be useless for any powered aircraft. Now I guess I have to spend my
money.
Vaughn
Old January 23rd 08, 11:12 PM posted to rec.aviation.soaring
Tom Nau
On Jan 23, 3:51*pm, "Vaughn Simon"
PCAS XRX $1795
PCAS MRX $549
* *Thanks for bringing up this subject. *I see that they have finally added an
audio output jack/headset cable to the MRX. *Without that feature, I considered
the MRX to be useless for any powered aircraft. *Now I guess I have to spend my
money.
Vaughn
I fly a Bonanza with Bose NR headsets and can hear the MRX alerts with
it mounted on the glareshield (without a headset cable).
Tom
Old January 23rd 08, 11:14 PM posted to rec.aviation.soaring
Andy[_1_]
On Jan 23, 2:51*pm, "Vaughn Simon"
The alarm is easily audible in my PA-28 when wearing my passive DC
13.4S headset. ANR headsets typical have no active cancelling in the
higher fequencies so I think it would also be easily audible wearing
ANRs. Having said that, mine is going in for a firmware update this
week and I decided to pay to add the audio jack in case I need it in
the future. I'm not sure it would be loud enough in a Husky for
example.
Andy
Floatation Devices Mike 'Flyin'8' Piloting 7 February 27th 05 11:21 PM
Traffic Warning skybug Aviation Marketplace 0 November 19th 04 07:33 AM
Traffic 2004 vs Ultimate Traffic Tlewis95 Simulators 3 August 13th 04 06:39 AM
Devices for avoiding VNE? John Galloway Soaring 100 April 12th 04 09:53 PM
New traffic warning device Loran Products 26 February 18th 04 01:14 AM
