For USA: Data Plate Exemption?
Old January 28th 08, 03:49 AM posted to rec.aviation.soaring
rlovinggood
Default For USA: Data Plate Exemption?
Can someone tell me the status of the old Data Plate Exemption for
gliders? There used to be a page on the SSA web page with the
exemption, but I can't find it now.
Is the Data Plate Exemption exempt? Do I now need a data plate?
Or, has the exemption been made permanent?
Thanks in advance for the help!
Ray Lovinggood
Carrboro, North Carolina, USA
Old January 28th 08, 05:23 AM posted to rec.aviation.soaring
Frank Whiteley
Ray Lovinggood
AFAIK, the letter is still required, but the links under the Govt
Liaison 2002 archive don't lead anywhere.
I've sent you PDF copies via e-mail.
Frank Whiteley
Old January 28th 08, 05:34 AM posted to rec.aviation.soaring
Ray,
I just searched the SSA website and found the following:
http://www.ssa.org/NewsArchive.asp?S...te&archive=All
However, the links to the required documents are broken. It apears they
haven't been moved to the new server. Hopefully they will appear in the
near future.
HP-14 "6F"
http://www.soaridaho.com/
"rlovinggood" wrote in message
Ray Lovinggood
Old January 28th 08, 02:27 PM posted to rec.aviation.soaring
rlovinggood
Frank,
Thank you for the information!
Ray
Frank Whiteley
Old January 28th 08, 06:29 PM posted to rec.aviation.soaring
Ian Cant
The exemption has to be renewed every two years, and
always seems to be reluctantly extended by the FAA.
When the only glass aircraft around were sailplanes,
we got the exemption [I believe for performance reasons,
possibly for appearance - anyone know the real history
For the last few years I have wandered around Oshkosh
and looked at other glass aircraft, experimentals and
LSAs. Some have an external metal dataplate, others
do not. Maybe the requirement has fallen into abeyance,
or maybe individuals have asked for and received similar
exemptions. Perhaps it is time for the industry, rather
than only the SSA, to ask for a permanent general waiver
for all glass aircraft. Internal metal dataplates
appear to serve the same purpose.
Ian
Old January 28th 08, 06:42 PM posted to rec.aviation.soaring
You should be able to access the FAA exemption database at http://aes.faa.gov/
Search for exemption number 4988, or for Soaring Society of America
under petitioner.
Or just search for "soaring" and see a list of everyone's soaring-
related exemptions.
Old January 28th 08, 09:17 PM posted to rec.aviation.soaring
Frank Whiteley
On Jan 28, 11:29 am, Ian Cant
Ian
The current extension expires October 2008.
Frank W
Old January 29th 08, 04:39 PM posted to rec.aviation.soaring
Go to the SSA site, login,
HomeNews& InformationSearch the Archives look for "Exemptions" and
scroll down till you find it. The original exemption is there and
also the current renewal.
Tom
Idaho
Ray Lovinggood
Engine Data Plate Micha³ Cebrowski Owning 3 April 12th 06 09:01 PM
data plate for 2-33 Peter Scarpelli Soaring 1 March 21st 06 01:53 AM
External Placard Exemption data sheets locaton Sam and Leigh Zimmerman Soaring 0 April 1st 04 03:05 PM
Mfg Data Plate Question Carl Orton Owning 9 November 6th 03 01:12 AM
Data Plate Exemption Letter Steve Bralla Soaring 8 October 13th 03 03:22 AM
