Polyurethane finish?
Old February 5th 08, 08:39 PM posted to rec.aviation.soaring
Uniform Zulu
Default Polyurethane finish?
I recently purchased a glider which was refinished
in polyurethane and I'm wondering what is the best
way to look after the finish?
Should I put something like wxblock on it or just use
a good automotive wax? should it be hard waxed and
buffed like gel coat?
What about fixing any problem areas? Is sanding a good
idea?
Any advice would be appreciated.
Old February 5th 08, 11:44 PM posted to rec.aviation.soaring
Capt. Geoffrey Thorpe
"Uniform Zulu" wrote in message
I would suggest startng with the manufacturer of the paint - many have "how
to take care of" information available
Geoff
Old February 6th 08, 03:08 PM posted to rec.aviation.soaring
JJ Sinclair
On Feb 5, 11:39*am, Uniform Zulu
idea?
We need more information there, Uniform Zulu.................What type
ship, who painted it, how many coats did he shoot on? If you have at
least 3 medium to wet coats, you can wet sand it with a rubber block
using 600, then 800 grit paper, then buff out with liquid buffing
compound and an 1800 rpm buffer with a wool pad. Repairing scuffed
tips requires the edges to be sanded with 220, then shot, when wet
sanding out this repair you may show the grey primer at the
edge..............that's why white primer is the best. PCL Polyprimer
907 white, it's PE.............use any wax that doesn't have silicone,
I use Mothers (milk?), don't like the way WX block goes on after
buffing the ship out.......doesn't seem to spread evenly.
JJ
Old February 6th 08, 06:37 PM posted to rec.aviation.soaring
Uniform Zulu
type
If you have at
a rubber block
liquid buffing
scuffed
shot, when wet
at the
PCL Polyprimer
have silicone,
goes on after
JJ
LS-3, I don't have much info on the finish (long story).
The finish is 10 years old and still looks good except
for a few rough areas on the wings. I'm not sure about
the paint thickness but it appears thin in areas on
the tops of the wings. I will probably take it down
to M&H next year to fix since any sanding on the tops
of wings will probably go through. Can you just shoot
new paint on these areas after sanding down and blend
in?
Old February 6th 08, 11:44 PM posted to rec.aviation.soaring
JJ Sinclair
Can you just shoot
in?
Yes, but any wet sanding at the edges runs the chance of going thin
and showing primer through. Not that hard to shoot the tops only with
enough paint to allow a complete sanding and buff-out. I did this on
my Genesis after the re-build, most areas were just scraped up, so I
filled and painted without primer in most areas.........came out good.
JJ
Old February 7th 08, 08:32 AM posted to rec.aviation.soaring
ventus2
I use Farecla G3 light cutting compound with a splash of water added to make
a toothpaste type consistency. Another splash of water on the wing with the
polish before I buff with a foam buff. Goes on consistently. I then use a
polish like Nu Finish and polish with a lambs wool buff.
I finish sanding with 2000 grade, spanwise. Comes up like a mirror.
Repairs are done by wet sanding the area with 400 (care not to sand through
to the primer outside of the repair area).
If repairing scratches by 'layering in" PU (for small chips or small
scratches), remember that PU will shrink to half its size when it dries.
Generally used for on field repairs.
If the area has not been prepared properly, you will get a shadow/watermark
around the repair when you sand it back.
Chris
Blistering of Finish Uniform Zulu Soaring 10 December 24th 07 05:40 PM
Quickie / Rutan plans with polyurethane foam [email protected] Home Built 3 March 28th 06 02:04 AM
Finish lines Thomas Knauff Soaring 72 May 24th 05 07:09 AM
Taking care of my Jantar polyurethane Miguel Lavalle Soaring 1 February 18th 04 03:41 PM
Best Polyurethane Paint for Homebuilt jls Home Built 2 February 8th 04 02:25 AM
