Soaring Safety
Old February 13th 08, 09:17 PM posted to rec.aviation.soaring
Default Soaring Safety
Last November, I chaired a panel at the local SSA affiliate (PASCO)'s
Soaring Safety Seminar entitled "Complacency: What Me Worry?" I wrote
up my part of that and made it available at
http://ee.stanford.edu/~hellman/soar...2007_talk.html
Just today, PASCO got a request from the Capetown S.A. soaring club to
reprint the article with the following explanation:
"The reason for writing to you is that my gliding club was unfortunate
to lose a member recently in a ridge accident. He was an extremely
experienced ridge pilot and only on his eighth flight in his brand new
DG808. Your PASCO Safety Seminar article titled "Complacency" is
therefore of particular relevance to our members."
My Soaring Safety page
http://ee.stanford.edu/~hellman/soaring/safety.html
has links to several other highly relevant articles. With respect to
ridge soaring and the too regular fatalities of "extremely experienced
ridge pilots" please see the links to Henry Combs article and JJ
Sinclair's. Gantenbrink's speech is a must read if you haven't seen
it, though I suspect most of you have. But, then again, it is worth
reading more than once.
Hoping this helps.
Martin
N56WT
Old February 14th 08, 03:26 PM posted to rec.aviation.soaring
Mike125
Very good post and links. I consider myself a novice ridge flyer and,
despite having done a fair amount of reading on the subject, have
never seen this phenomenon addressed. Being low on ridge experience, I
tend to give the mountain a pretty wide berth but, as my confidence
level goes up and I start flying closer, the chances of encountering
this will increase. It has happened to me only a couple times at
altitude (once while still on tow) and, initially, scared me pretty
good each time. Being at what seems to be a 90 degree bank with full
opposite control inputs is a little disconcerting. A few seconds of
"What the*#!%?" followed by "Wow! Let me get back to that thermal!"
Great food for thought as the ridge season in the northeast
approaches.
Old February 14th 08, 11:06 PM posted to rec.aviation.soaring
to lose a member recently in a ridge accident. *He was an extremely
Hoping this helps.
Martin
N56WT
In the Henry Combs article, what did happen to Chet Lymon?
He survived and so did/does he confirm his roll control authority was
overpowered?
Old February 15th 08, 06:36 AM posted to rec.aviation.soaring
Mark Jardini
This discussion brings to mind an episode I had relatively early in my
soaring life. After licensing at Tehachepi in a 2-33, I went to
Crystal to
transition to glass in their Grob 103's. After being cleared to solo I
was flying along the San Gabriel's in an area that had been shown to
me.
The lift was sketchy and I was flying long passes through bands of
weak lift, not very close to the mountain, (I was and still am quite
cowardly). After hitting a strengthening patch of lift through two
passes, I had the brilliant idea to try circling. I made two circles
just like it was any other thermal I had flown and then, between
heartbeats, It all went to schist. I heard a loud bang and instantly i
was no longer flying. the car keys in my shirt pocket were pinned
against the canopy and all the gravel and dust on the floor was
floating in front of me. my angle of bank entering into this was
shallow and I think both wings hit at the same time. If it had been
one wing only, I would have been vertical or inverted faster than I
could have moved the controls to react.
Luckily I was pointed away from the mountain, and recovery was to
simply nose down and pull out. My own personal recovery took
considerably longer. There is no skill in the world that could tame
that kind of sharp edged shear while rock polishing, in my estimation.
Mark Jardini
Old February 15th 08, 04:08 PM posted to rec.aviation.soaring
JJ Sinclair
Sadly, we lost Stew Kissel shortly after I wrote "Don't Smack the
Mountain-101", so we need to add yet another name to the list of
"Mysterious high energy impacts on the side of a mountain". I live by
the rules I stated and so far (35 years & 5000 hours in the Sierras &
Whites) they have kept me from impacting the mountain.
JJ
Old February 15th 08, 05:07 PM posted to rec.aviation.soaring
overpowered?
I checked with my friend who knew Combs and gave me the article, but
so far he hasn't been able to provide an answer to the above question.
I did do a search of the NTSB database and found the report attached
below which says he encountered wind shear. The longer report lists
the wind as 270@13, so I suspect they really meant a thermally induced
wind shear. If that was the case, it wasn't quite the same mechanism
that Combs described but the point is still there. Anytime we fly
close to terrain, life is much more dangerous since there's less time
(no time sometimes) to recover from an anomaly -- be it a wing lifted
(as Combs describes), wind shear that causes a stall, etc.
Hope this helps.
Martin
NTSB Identification: LAX84FA315 .
The docket is stored on NTSB microfiche number 25291.
14 CFR Part 91: General Aviation
Accident occurred Saturday, May 26, 1984 in LLANO, CA
Aircraft: Bölkow PHOEBUS A-1, registration: N7700
Injuries: 1 Serious.
CIRCLING IN LIFT NEAR A HIGH RIDGE THE SAILPLANE ENCOUNTERED WHAT THE
PLT REFERRED TO AS WIND SHEAR. LOSING CONTROL, THE SAILPLANE COLLIDED
WITH A TREE BEFORE IMPACTING THE GROUND.
The National Transportation Safety Board determines the probable
cause(s) of this accident as follows:
WEATHER CONDITION..WINDSHEAR
AIRSPEED(VS)..NOT MAINTAINED..PILOT IN COMMAND
Old February 15th 08, 08:39 PM posted to rec.aviation.soaring
Shawn[_5_]
Crystal to
me.
"Going to schist" When rock polishing goes bad.
Yeah, yeah, I know what your thinking "How gneiss."
Shawn
Old February 16th 08, 01:13 AM posted to rec.aviation.soaring
tommytoyz
I remember reading an article, I thought it was Henry Combs, but not
sure, about a technique of rolling inverted deliberately and moving
away from the mountain inverted, when encountering such a gust.
It made sense to me, if you roll authority is less than the strength
of the gust, then don't fight it and even reverse input and let
yourself go inverted. You can then turn away inverted, or at least not
into the mountain. Sounds like a Judo move to me.
Does anyone remember this article or concur with this technique?
Old February 16th 08, 03:46 AM posted to rec.aviation.soaring
Crystal to
me.
Shawn
Oh, that's just marbelous.
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 [email protected] Soaring 0 November 9th 07 12:15 AM
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA [email protected] Soaring 0 September 11th 06 04:48 AM
Soaring Safety programs at the SSA Convention Burt Compton - Marfa Soaring 0 January 21st 06 04:40 AM
Soaring Safety Seminar - SSA Convention Burt Compton Soaring 0 January 26th 04 04:57 PM
Soaring Safety Foundation invitation Burt Compton Soaring 0 January 18th 04 03:51 PM
